In/Exclude User Data
On 28/03/2014 at 12:44, xxxxxxxx wrote:
Cinema 4D Version: 13
Platform: Windows ;
I can't figure out how to get at the items inside of an In/Exclude gizmo when it's created with User Data.
I can get the items from the In/Exclude gizmo just fine when it's created in my plugin code.
But for some strange reason. I can't get at them if it's created with User Data.//The object that has the In/Exclude UD entry on it BaseObject *obj = doc->SearchObject("HolderObject"); //Get the master UD container DynamicDescription *ud = obj->GetDynamicDescription(); //Get the first UD entry where the In/Exclude gizmo is sitting DescID firstUD(DescLevel(ID_USERDATA, DTYPE_SUBCONTAINER,0), 1); InExcludeData *in_ex = (InExcludeData* )ud->Find(firstUD); //<---Wrong? LONG count = in_ex->GetObjectCount(); //<---Jibberish!! GePrint(LongToString(count));
On 28/03/2014 at 14:40, xxxxxxxx wrote:
Never mind.
After hours of trying everything in my notes. I eventually hit upon the correct code.Here's an example in case anyone needs it.
//The object that has the In/Exclude UD entry on it BaseObject *obj = doc->SearchObject("HolderObject"); //Get the master UD container DynamicDescription *ud = obj->GetDynamicDescription(); //Get the first UD entry DescID firstUD(DescLevel(ID_USERDATA, DTYPE_SUBCONTAINER,0), 1); //Get the data from the UD gizmo and put it in "d" GeData d; obj->GetParameter(firstUD, d, DESCFLAGS_GET_0); //Put the data from "d" into a new InExcludeData type instance variable called "in_ex" InExcludeData *in_ex = (InExcludeData* )d.GetCustomDataType(CUSTOMDATATYPE_INEXCLUDE_LIST); //Get all of the objects inside of the In/Exclude gizmo //Then get their names and global positions LONG count = in_ex->GetObjectCount(); if(count > 0) { for(LONG i=0; i<count; ++i) { BaseList2D *entry2D = in_ex->ObjectFromIndex(doc, i); GePrint(entry2D->GetName()); BaseObject *entry = static_cast<BaseObject*>(entry2D); //Convert from a BaseList2D to a BaseObject type Matrix objMtx = entry->GetMg(); GePrint(RealToString(objMtx.off.x) + " " + RealToString(objMtx.off.y) + " " + RealToString(objMtx.off.z)); } }
On 10/04/2014 at 12:44, xxxxxxxx wrote:
Hi Scott,
When i use static_cast to convert from the BaseList2D to a BaseObject, I`m getting the error:
C2440: 'type cast' : cannot convert from 'const LVector' to 'int' c:\program files (x86)\microsoft visual studio 10.0\vc\include\numeric
The line of code i`m using is as follows:
BaseObject *curObj = static_cast<BaseObject*>(objList->ObjectFromIndex(doc, i));
Any clues what is going on here?
On 10/04/2014 at 13:51, xxxxxxxx wrote:
That line of code looks ok to me. The problem must be coming from someplace else.
The error seems to indicate that you might be using a vector as the iterator. Instead of LONG(i).
Also make sure that your objList variable is written like this:InExcludeData *objList = (InExcludeData* )d.GetCustomDataType(CUSTOMDATATYPE_INEXCLUDE_LIST);
Also don't forget about the In/Exclude counter bug too.
If you delete an object from the OM that's in that list. Your code will crash C4D because the iteration count is no longer accurate.This is a workaround for handling that scenario:
//There is a bug in the In/Exclude list that the count value doesn't update when an object is deleted from the OM //This is a workaround to that manually deletes an object from the list if the object doesn't exist in the OM #include "customgui_inexclude.h" BaseObject *mylight = doc->SearchObject("Light"); //A pointer to the light object with an inexclude list on it BaseContainer *data = mylight->GetDataInstance(); //Get the lights data //Get the light's in/exclude list and assign it to a variable InExcludeData *in_ex_List = (InExcludeData* )data->GetCustomDataType(LIGHT_EXCLUSION_LIST, CUSTOMDATATYPE_INEXCLUDE_LIST); if(in_ex_List && in_ex_List->GetObjectCount() > 0) { for(int i=0; i < in_ex_List->GetObjectCount(); ++i) { //Find the objects that are in the in/exclude List and assign them to a variable BaseList2D *ListObj = in_ex_List->ObjectFromIndex(doc,i); if(!ListObj) { //An object that has been deleted from the OM does not update the list's count value(BUG?) //So we have to manually subtract one from the count value if(!in_ex_List->DeleteObject(i)) break; //Delete the object from the In/Exclude list it's not in the OM anymore mylight->SetDirty(DIRTYFLAGS_DATA); mylight->Message(MSG_UPDATE); } } }
On 10/04/2014 at 15:20, xxxxxxxx wrote:
Thanks for the help Scott.
You
re right it isn
t with that. I assumed, as it mentionscast
that it was regards the static_cast.What i figured out was, in VisualStudio ( 2010 Express ) if i go into Tools / Options / Projects and Solutions / Build and Run i can change the Verbosity of the build output.. Pretty useful as it lets me find where the problem is being called.. Turning on line numbers is useful as well :)
