Import image to textures
  • On 25/03/2014 at 23:41, xxxxxxxx wrote:
    Cinema 4d -- > Edit --> Project Info -->Textures(Tab) --> import jpg files for texture.
    I have 2 jpg to import in my module. I used above method to import the jpg file manually. I planned to automate it using Python. I thought I can get the  c4d.BaseObject() id for the texture but I cant. Is there anyway I can automate the process. Any advice and reference linkis high appreciated. Thanks.
  • On 11/04/2014 at 07:27, xxxxxxxx wrote:
    Textures as displayed in the Texture Manager are no certain entity and modifying them the
    way the Texture Manager does is not supported by the API. You can get a list of all used textures
    in the document via BaseDocument.GetAllTextures() if that helps you.
    Best,
    -Niklas
