On 24/03/2014 at 12:23, xxxxxxxx wrote:
I am adding menu items to a python created window using:
self.MenuSubBegin("Set") self.MenuAddString(10017,"Local&c&") self.MenuSubEnd()
Trying to toggle the check mark on the menu I am using:
self.MenuInitString(10017,True,False)
Where in the documentation, False is where the check status goes. So false should be unchecked and true should be checked. I can not get the check to do anything.
Am I setting this up wrong?
On 24/03/2014 at 12:34, xxxxxxxx wrote:
I can confirm your problem. Looks like a bug, I'll forward this to the devs. You'll need to flush the menu and re-build it.
Best, -Niklas
On 24/03/2014 at 12:35, xxxxxxxx wrote:
Thanks!
On 25/03/2014 at 00:49, xxxxxxxx wrote:
The &c& always checks the entry. You have to rename or build a new menu. To check the menu remove the &c& and check it only with self.MenuInitString. If you need a check when the dialog opens use this function also in CreateLayout with checked=True. Hope this helps.
Cheers, s_rath
On 25/03/2014 at 01:11, xxxxxxxx wrote:
Thanks for the info, Sebastian. That explains why my tests didn't work, either.
import c4d class Dialog(c4d.gui.GeDialog) : def CreateLayout(self) : self.MenuSubBegin("File") self.MenuAddString(1000, "Open ...") self.MenuAddString(1001, "Save ...") self.MenuAddString(1002, "Close") self.MenuInitString(1001, False, False) self.MenuInitString(1002, False, False) self.MenuSubEnd() self.MenuFinished() return True def Command(self, id, msg) : if id == 1000: self.MenuInitString(1001, True, False) self.MenuInitString(1002, True, False) self.MenuFinished() elif id == 1002: self.MenuInitString(1001, False, False) self.MenuInitString(1002, False, False) self.MenuFinished() return True dlg = Dialog() dlg.Open(c4d.DLG_TYPE_ASYNC)
On 25/03/2014 at 08:49, xxxxxxxx wrote:
Thanks for the help guys!
