On 07/03/2014 at 04:59, xxxxxxxx wrote:
User Information: Cinema 4D Version: 15 Platform: Mac OSX ; Language(s) : C++ ;
--------- I'm creating some helper methods for the C4DAtom::GetParameter method, since using it as is, is a bit verbose. Here's a example of my helper for a Float.
Bool GetParameter(GeListNode* node, const Int32 id, Float& value) { GeData d; if(node->GetParameter(id, d, DESCFLAGS_GET_0)) { value = d.GetFloat(); return true; } return false; } //Usage: Float offset; if(!GetParameter(op, TEST_EFFECTOR_OFFSET, offset)) return;
This works and sets the offset correctly as a Float set by the user in the GUI.
But when I try to do the same thing to a custom data type, in this case SplineData, the data disappears when out of the helper function's scope. Here's the code:
Bool GetParameter(GeListNode* node, const Int32 id, SplineData *&splineData) { GeData d(CUSTOMDATATYPE_SPLINE, DEFAULTVALUE); if(node->GetParameter(id, d, DESCFLAGS_GET_0)) { splineData = (SplineData* )d.GetCustomDataType(CUSTOMDATATYPE_SPLINE); cout << splineData->GetKnotCount() << endl; **// outputs 4, correct** return true; } return false; } //Usage: SplineData* splineData; if(!GetParameter(op, TEST_EFFECTOR_SPLINE, splineData)) return; if(splineData) cout << splineData->GetKnotCount() << endl; **// outputs 0, incorrect**
I can't figure out how to get the correct SplineData out of the helper function. Any help on this would be great as I'm relatively new to c++.
On 08/03/2014 at 07:42, xxxxxxxx wrote:
You need to copy the SplineData with SplineData::CopyTo() and remove the address-of operator from the splineData parameter.
Just declare the GeData variable as you've done in the Float example.
Remember to either use AutoAlloc<SplineData> or free it with SplineData::Free().
On 08/03/2014 at 12:06, xxxxxxxx wrote:
That was it. Thanks DavidW!
On 08/03/2014 at 12:27, xxxxxxxx wrote:
Could you please post your working version fusepilot?
On 08/03/2014 at 15:51, xxxxxxxx wrote:
Yep,
Bool GetParameter(GeListNode* node, const Int32 id, SplineData *splineData) { GeData d; if(node->GetParameter(id, d, DESCFLAGS_GET_0)) { SplineData *sd; sd = (SplineData* )d.GetCustomDataType(CUSTOMDATATYPE_SPLINE); sd->CopyTo(splineData); return true; } return false; } //Usage: AutoAlloc<SplineData> splineData; if(!GetParameter(op, TEST_EFFECTOR_SPLINE, splineData)) return;
On 08/03/2014 at 16:24, xxxxxxxx wrote:
Thanks.
On 25/03/2014 at 09:20, xxxxxxxx wrote:
I hate to bring this up again. But in the process of making these functions work for R13, I've noticed that version of the SDK does not contain a SplineData::CopyTo. And all the solutions I've found about C++ deep copying suggest creating something like, well the CopyTo function. Which I don't think I can do.
So how were you suppose to do this prior to R14 when SplineData::CopyTo was introduced? Or how can I create my own SplineData::CopyTo helper function?
On 26/03/2014 at 18:03, xxxxxxxx wrote:
I figured out a solution. Just copy all of the CustomSplineKnots over.
void CopySplineDataTo(SplineData* src, SplineData *dst) { vector<CustomSplineKnot*> knots; for (LONG i = 0; i < src->GetKnotCount(); i++) { knots.push_back(src->GetKnot(i)); } LONG num_knots = knots.size(); dst->DeleteAllPoints(); dst->MakePointBuffer(num_knots); for (LONG k = 0; k < num_knots; k++) { CustomSplineKnot* knot = knots[k]; dst->InsertKnot(knot->vPos.x, knot->vPos.y); CustomSplineKnot* new_knot = dst->GetKnot(k); CopyMem(knot, new_knot, sizeof(CustomSplineKnot)); } } Bool Get(GeListNode *node, const LONG id, SplineData *spline_data) { GeData d; if(node->GetParameter(id, d, DESCFLAGS_GET_0)) { SplineData *sd; sd = (SplineData* )d.GetCustomDataType(CUSTOMDATATYPE_SPLINE); #if API_VERSION >= 14000 sd->CopyTo(spline_data); #else CopySplineDataTo(sd, spline_data); #endif return true; } return false; }
