On 30/10/2002 at 11:20, xxxxxxxx wrote:
hi there
what i really miss in c4d is a cable-tool that allows the following things:
calculate a sweep-nurbs splines bezier tangents using a free 'elasticity value' (C). it should take care of objects that are positioned below the spline starting and ending point (A). it must recognise any object in any direction (D). the cables must have a input field for a 'specific' weight (B) of the cable material.
the second image shows the spline direction from yellow to red. yellow is up in the cable y-position.
the plugin should have a thickness adjustment and most important: THE OUTER RADIUS OF THE FORM-SPLINE HAS TO BE IN CONTROLL AND NOT ONLY THE SPLINE ITSELF.
i think it is a tricky mission but i think someone would pay some money for it. i would! please notice that i'm not into programming an therefore i do not know how complicated this is. if someone can solve this problem, thank you so much in advance!
