On 03/03/2014 at 06:25, xxxxxxxx wrote:
Is it possible when i press a button a function is called that keeps checking if the time of timeline is changed. So that i can run an other function every time a frame update is called.
I want to do this to clone an objects global matrix to another object every time timeline changes.
I know u can do this with python node or tag but that's not the solution I'm searching for. Or can enable/disable a tag with plugin?
Greets, GiMars
On 03/03/2014 at 08:28, xxxxxxxx wrote:
Hi This thread touches that problem : http://forums.cgsociety.org/archive/index.php/t-1090235.html
Cheers Bonsak
On 04/03/2014 at 06:00, xxxxxxxx wrote:
I got it to work! Im using messageData that checks for EVMSG_CHANGE. And made a function that creates a null object with an expresso tag and a python node that is frame dependent that calls c4d.EventAdd() everyframe and that does the job
Great thread u posted Thanks Bonsak!
On 04/03/2014 at 06:13, xxxxxxxx wrote:
Yw
-b
