Render Path Change based on multipass
On 26/02/2014 at 13:21, xxxxxxxx wrote:
Hey!
i come from maya originally, and the way c4d saves render passes as a million files in a single folder is really not the best method for my workflow. im currently trying to figure out a way to make a plugin that would intercept the render data's path and add subfolders based on multipass layers. does anyone have a good resource or spot where i can understand how c4d renders and saves files?
On 06/03/2014 at 00:12, xxxxxxxx wrote:
HI man.
I was after this idea some time ago, but didn't find a solution to intersect render, so I ended up making a plugin RENOMI that you would normally run After render is done.
Now, based on your MultiPass settings (Object Buffer names, other passes) RENOMI will rename those files / put them in separate folders / update compositing file / etc.
http://www.rendertom.com/plugins/renomi/
On 06/03/2014 at 11:02, xxxxxxxx wrote:
here is a script i use for this. it has some limitations - if you need it often renomi is defently the bedder choise in case of other languarges and comp tools
    from c4d import gui
    import commands
    import os
    import shutil
    from glob import glob
    ### postwendend.com ###
    ### tobias hoffmann ###
    ### [email protected] ###
    def listdir(d) :
        return  [os.path.join(d,fn) for fn in next(os.walk(d))[2]]
    def main() :
        rd = doc.GetActiveRenderData()
        rd_long = doc.GetActiveRenderData()
        vp = rd.GetFirstMultipass()
        single_path = rd[c4d.RDATA_PATH]
        multi_path = rd[c4d.RDATA_MULTIPASS_FILENAME]
        multi_path_global = multi_path
        multi_path_arr = []
        multi_path_arr = multi_path.split("\")
        i = 0
        arr_len = len (multi_path_arr)
        arr_len = arr_len - 1
        multi_path = ""
        while i < arr_len:
            multi_path = multi_path + multi_path_arr[i] + "\"
            i = i + 1
        object_buffer_arr = []
        object_bufferID_arr = []
        pfadarr = []
        file_type_arr = []
        file_name =  multi_path_arr[arr_len]
        i = 0
        j = 0
        k = 0
        while vp:
            if vp.GetTypeName() == "Object Buffer":
                object_buffer_arr.append (vp.GetName())
                object_bufferID_arr.append (vp[c4d.MULTIPASSOBJECT_OBJECTBUFFER])
                j = j + 1
            mp_name = vp.GetName()
            multipass_type = ""
            if mp_name == "RGBA Image":
                multipass_type = "rgb"
            elif mp_name == "Ambient":
                multipass_type = "ambient"
            elif mp_name == "Ambient Occlusion":
                multipass_type = "ao"
            elif mp_name == "Atmosphere":
                multipass_type = "atmos"
            elif mp_name == "Atmosphere (Multiply)":
                multipass_type = "atmosmul"
            elif mp_name == "Caustics":
                multipass_type = "caustics"
            elif mp_name == "Depth":
                multipass_type = "depth"
            elif mp_name == "Diffuse":
                multipass_type = "diffuse"
            elif mp_name == "Global Illumination":
                multipass_type = "gi"
            elif mp_name == "Illumination":
                multipass_type = "illum"
            elif mp_name == "Material Color":
                multipass_type = "matcolor"
            elif mp_name == "Material Diffusion":
                multipass_type = "matdif"
            elif mp_name == "Material Environment":
                multipass_type = "matenv"
            elif mp_name == "Material Luminance":
                multipass_type = "matlum"
            elif mp_name == "Material Reflection":
                multipass_type = "matrefl"
            elif mp_name == "Material Refraction":
                multipass_type = "matrefr"
            elif mp_name == "Material Specular":
                multipass_type = "matspec"
            elif mp_name == "Material Specular Color":
                multipass_type = "matspeccol"
            elif mp_name == "Material Transparency":
                multipass_type = "mattrans"
            elif mp_name == "Motion Vector":
                multipass_type = "motion"
            elif mp_name == "Material Normal":
                multipass_type = "normal"
            elif mp_name == "Specular":
                multipass_type = "specular"
            elif mp_name == "Shadow":
                multipass_type = "shadow"
            elif mp_name == "Material UVW":
                multipass_type = "uv"
            elif mp_name == "Reflection":
                multipass_type = "refl"
            elif mp_name == "Refraction":
                multipass_type = "refr"
            elif mp_name == "Post Effects":
                multipass_type = "post"
            path_temp = (multi_path)
            file_type_arr.append (multipass_type)
            path_temp =  os.path.normpath(path_temp)
            pfadarr.append (path_temp)
            vp = vp.GetNext()
        for item in pfadarr:
           pos1 = pfadarr[i] + "\" + file_name +  "_" + file_type_arr [i]+"*"
           pos1 =  os.path.normpath(pos1)
           pos2 = pfadarr[i] + "\" + file_type_arr [i] + "\"
           pos2 =  os.path.normpath(pos2)
           pos3 = pfadarr[i] + "\" + file_type_arr [i] + "\"
           pos3 =  os.path.normpath(pos3)
           os.system ("mkdir " + pos3)
           os.system ("move " + pos1 + " " + pos2)
           i = i + 1
        renderoutput = []
        renderoutput = listdir(multi_path)
        renderoutput_len = len ( renderoutput )
        i = 0
        while i < renderoutput_len:
            renderoutput_filename= renderoutput[i].replace(multi_path, "")
            while k < j:
                str_helper = "object_" + str(object_bufferID_arr[k])
                if renderoutput[i].find ( str_helper ) > 0:
                    if object_buffer_arr[k] == "Object Buffer":
                        renderoutput_filename = renderoutput_filename.replace(str_helper, object_buffer_arr[k] + "_" + str(object_bufferID_arr[k]))
                        if os.path.isdir ( multi_path + "Object_Buffer" + str(object_bufferID_arr[k])) == 0:
                            os.system ("mkdir " + multi_path + "Object_Buffer_" + str(object_bufferID_arr[k]))
                        os.rename ( renderoutput[i], multi_path  +  "Object_Buffer_" + str(object_bufferID_arr[k]) + "\" + renderoutput_filename )
                        renderoutput_filename = renderoutput_filename.replace("_object" , "_" + object_buffer_arr[k] )
                        if os.path.isdir ( multi_path + object_buffer_arr[k])  == 0:
                            os.system ("mkdir " +  multi_path + object_buffer_arr[k])
                        os.system ("move " + renderoutput[i] + "    "  + multi_path + object_buffer_arr[k] + "\" + renderoutput_filename)
                k = k + 1
            k = 0
            i = i + 1
    if __name__=='__main__':
