On 21/02/2014 at 07:54, xxxxxxxx wrote:
Is there a way to close a script that I loaded in the Script Manager? If I choose 'close' from the File menu it closes the Script Manager. If I choose 'delete' it actually deletes the .py file from the drive.
There are times I open versions of previous scripts to look at how I did things and I would like to be able to close them or unload them.
thanks, .del
On 21/02/2014 at 16:15, xxxxxxxx wrote:
Scripts get stored here. "C:\Users\USERNAME\AppData\Roaming\MAXON\CINEMA 4D\library\scripts" move it from there and then cinema will ask you if you want to re-save, say no. I wish there was a faster cleaner way.
