On 10/02/2014 at 03:13, xxxxxxxx wrote:
I guess, my only solution is to ditch the bitmaps
On 11/02/2014 at 06:51, xxxxxxxx wrote:
What you've tried would exit the GetDEnabling() function immediately.
def GetDEnabling(self, node, id, t_data, flags, itemdesc) :
isoff1=node[AB_ON1]
isoff2=node[AB_ON2]
isoff3=node[AB_ON3]
if (id[0].id == AB_NUM_B1) : return isoff1==1
if (id[0].id == AB_DENS_B1) : return isoff1==1
if (id[0].id == AB_START_B1) : return isoff1==1
if (id[0].id == AB_END_B1) : return isoff1==1
if (id[0].id == AB_SEED_B1) : return isoff1==1
if (id[0].id == AB_ON2) : return isoff1==1
if (id[0].id == AB_NUM_B2) : return (isoff1*isoff2)==1
if (id[0].id == AB_DENS_B2) : return (isoff1*isoff2)==1
if (id[0].id == AB_START_B2) : return (isoff1*isoff2)==1
if (id[0].id == AB_END_B2) : return (isoff1*isoff2)==1
if (id[0].id == AB_SEED_B2) : return (isoff1*isoff2)==1
if (id[0].id == AB_ON3) : return (isoff1*isoff2)==1
if (id[0].id == AB_NUM_B3) : return (isoff1*isoff2*isoff3)==1
if (id[0].id == AB_DENS_B3) : return (isoff1*isoff2*isoff3)==1
if (id[0].id == AB_START_B3) : return (isoff1*isoff2*isoff3)==1
if (id[0].id == AB_END_B3) : return (isoff1*isoff2*isoff3)==1
if (id[0].id == AB_SEED_B3) : return (isoff1*isoff2*isoff3)==1
try:
return c4d.plugins.NodeData.GetDEnabling(self, node, id, t_data, flags, itemdesc)
except (AttributeError, TypeError) :
# Bug up to R14, AttributeError seems to be raised randomly for
# BitmapButton items and TypeError sometimes for other things.
-Niklas
On 12/02/2014 at 04:54, xxxxxxxx wrote:
It still returns the same errors
I believe I will really have to ditch the bitmaps.
It is a shame, since I made some nice graphics
Rui Bastista
