On 31/01/2014 at 08:20, xxxxxxxx wrote:
User Information: Cinema 4D Version: R15 Platform: Windows ; Language(s) : C++ ;
--------- (Also) in C++ I do not get the little arrow in front of the date and time to show (expand) the calendar and the clock?
BaseContainer dtcont; dtcont.SetBool(DATETIME_TIME_CONTROL, true); dtcont.SetBool(DATETIME_DATE_CONTROL, true); dtcont.SetBool(DATETIME_NOW_BUTTON, true); dt = (DateTimeControl* )AddCustomGui(1002, DATETIME_GUI,"Date/Time",BFH_SCALEFIT|BFV_SCALEFIT,0,0,dtcont);
On 31/01/2014 at 11:25, xxxxxxxx wrote:
This is one of those odd gizmos that have to be expanded in the Init() function. Not in the CreateLayout() function. That tripped me up too.
Bool MyDialog::InitValues(void) { dt->SetLayoutMode(LAYOUTMODE_MAXIMIZED); //Works like "OPEN" does in the .res file return TRUE; }
Also. Be aware that most of the DT base container options are now depreciated.
On 01/02/2014 at 02:46, xxxxxxxx wrote:
Great, thank you. Does it also means that we have to program the little collapse/expand arrow in front, ourselfs? At the moment there is no such little arrow, so I assume you have to do it yourself. Regards, Pim
On 01/02/2014 at 07:44, xxxxxxxx wrote:
Yeah. I think you'll have to create that effect yourself. Using a button that swaps an image when pressed. Or some other sort of trickery. That little arrow only seems to get created when you use these custom gizmos in a Node based plugin. But not in a GeDialog plugin.
This is an example of creating the DT gizmo dynamically for a node (tag) plugin. Just like when using the .res file to create the gizmo for these kinds of plugins. That little arrow automatically get created for us. It's a built-in thing for the Node plugins that we get for free.
Bool SimpleTag::GetDDescription(GeListNode *node, Description *description,DESCFLAGS_DESC &flags) { //We will load the DateTime GUI into the first description level(much like loading UD entries into levels) DescID did = DescLevel(1, DTYPE_NONE, 0); BaseContainer settings; settings.SetLong(DESC_CUSTOMGUI, DATETIME_GUI); settings.SetString(DESC_NAME,"DateTime"); settings.SetString(DESC_SHORT_NAME,"DateTime"); settings.SetBool(DATETIME_NOW_BUTTON, TRUE); if (!description->SetParameter(did,settings,DescLevel(ID_OBJECTPROPERTIES))) return FALSE; flags |= DESCFLAGS_DESC_LOADED; return TRUE; }
On 01/02/2014 at 14:46, xxxxxxxx wrote:
Thanks, indeed when using User Data and a Date/Time field you get the little arrow. But doing that yourself in c++ is not a big issue. We discussed it in one of my previous posts. Thanks for the example.
Pim
