On 27/01/2014 at 13:27, xxxxxxxx wrote:
Hey i try to get the Message that the project change
the question is what is the right id
def CoreMessage(self, id, bc) : if id == xx: #chang projekt
On 27/01/2014 at 13:28, xxxxxxxx wrote:
try c4d.EVENT_MSG
Cheers, Seb
On 27/01/2014 at 13:50, xxxxxxxx wrote:
thx seb
class stage_message(plugins.MessageData) : def CoreMessage(self, id, bc) : if id == c4d.EVENT_MSG:
AttributeError: 'module' object has no attribute 'EVENT_MSG'
On 29/01/2014 at 12:55, xxxxxxxx wrote:
do I understand the CoreMessage wrong ?
On 29/01/2014 at 14:48, xxxxxxxx wrote:
Try c4d.EVMSG_CHANGE
On 29/01/2014 at 14:53, xxxxxxxx wrote:
thx niklas
the change message will call often - i need only the project change -
On 30/01/2014 at 02:21, xxxxxxxx wrote:
What do you understand under the term "project change"?
On 30/01/2014 at 03:39, xxxxxxxx wrote:
menu - window - switch between different projects
On 30/01/2014 at 03:42, xxxxxxxx wrote:
So you want to know when the user switched to another project? It sounded like you want to know when a project was changed , ie. modified.
On 30/01/2014 at 09:03, xxxxxxxx wrote:
This topic has been discussed several times in the forum. For example in this thread: Notification on change of active document
On 31/01/2014 at 01:50, xxxxxxxx wrote:
thanks to all of you . got it
