Downloading a file from the Internet
  • On 20/01/2014 at 06:54, xxxxxxxx wrote:
    Cinema 4D Version:   R15
    Platform:   Windows  ;
    I think I need to use HyperLinkCustomGui and HyperlinkData to download a file from the Internet.
    Not to display it (that is done with HTMLViewerCustomGui), but to read and process it.
    The manuals tells me "Hyper link data type ([CUSTOMDATATYPE_HYPER_LINK_STATIC](file:///D:/Users/pgrooff/Documents/pim/c4d/c++%20R15%20sdk/help/pages/customgui_hyperlink/enum_CUSTOM_HYPER_LI364.html#customdatatype_hyper_link_static1)) for use with the [HyperLinkCustomGui](file:///D:/Users/pgrooff/Documents/pim/c4d/c++%20R15%20sdk/help/pages/customgui_hyperlink/class_HyperLinkCusto821.html) GUI. Has to be created with [Alloc()](file:///D:/Users/pgrooff/Documents/pim/c4d/c++%20R15%20sdk/help/pages/lib_aes/class_AES9.html#alloc0) and destroyed with [Free()](file:///D:/Users/pgrooff/Documents/pim/c4d/c++%20R15%20sdk/help/pages/lib_aes/class_AES9.html#free1). You can use[AutoAlloc](file:///D:/Users/pgrooff/Documents/pim/c4d/c++%20R15%20sdk/help/pages/ge_autoptr/class_AutoAlloc33.html) to automate the allocation and destruction based on scope."
    However, I do not know how to use them and I cannot find an example.
    	BaseContainer hyperlinkc;
    	hlcgsibl = (HyperLinkCustomGui* )AddCustomGui(1002, CUSTOMGUI_HYPER_LINK_STATIC, "Hyperlink", BFH_SCALEFIT|BFV_SCALEFIT, 900, 200, hyperlinkc);
    	String linkTextsIBL = "http://www.hdrlabs.com/sibl/index.html";
    	String labelTextsIBL = "Smart IBL overview";
    	hlcgsibl->SetLinkString(&linkTextsIBL, &labelTextsIBL);
    Pim
  • On 20/01/2014 at 08:01, xxxxxxxx wrote:
    Hi Pim,
    You just need to set HYPERLINK_IS_LINK to true in the HyperLinkCustomGui container.
  • On 21/01/2014 at 04:01, xxxxxxxx wrote:
    Ok, then how do I tell cinema 4d where to store the downloaded data.
    Do I need to Alloc the HyperlinkData and put that somewhere in the container?
  • On 21/01/2014 at 05:52, xxxxxxxx wrote:
    Pim, do you want to download a file or display a link in a dialog where the user can download a file?
  • On 21/01/2014 at 11:53, xxxxxxxx wrote:
    I want to download a file.
    After downloading I will display the contents of the file using the treeview as we discussed in another post.
    By the way, in Python it is very easy to do.
    In our lon-lat plugin we connect to OSM, query the site and use the result (the contents) in our plugin.
  • On 23/01/2014 at 05:53, xxxxxxxx wrote:
    Originally posted by xxxxxxxx
    Hi Pim,
    Setting a link now works.
    	//set labelText as link.
    	hyperlinkc.SetBool(HYPERLINK_IS_LINK, true);
    	String linkTextsIBL = "http://www.link.com/index.html";
    	String labelTextsIBL = "Link text";
    However still the question how to download data in a for C++ accessible form?
    E.g. I want to download http://www.grooff.eu/countries.txt and put the input of this file in a treeview.
    Use HyperlinkData, but how?
  • On 26/01/2014 at 06:52, xxxxxxxx wrote:
    Still very unclear, how to download a file from the internet.
    I can use HyperLinkCustomGui to define a link, but when clicked the file is openen in a browser and the file is not downloaded.
    The manual tells to use HyperLinkData, but how?
    In the example below, I do not use it.
    	String linkTextsIBL = "http://www.grooff.eu/pictures/download.txt";
    	String labelTextsIBL = "Download test file.";
    	String pStrLink, pStrText;
    	hlcgsibl->GetLinkString(&pStrLink, &pStrText);
    HyperLinkData is only useful if a HYPERLINK parameter is defined in a description resource.
    It allows to get/set the hyperlink text and link strings.
    HyperLinkCustomGui only displays a link. If you need to download a file from an internet URL take a look at these pages on Stackoverflow:
    http://stackoverflow.com/questions/1129194/download-a-url-in-c
    http://stackoverflow.com/questions/1636333/download-file-using-libcurl-in-c-c
  • On 01/02/2014 at 02:56, xxxxxxxx wrote:
    Thanks, I can now run curl using a command file and thus download a file.
    I can get curllib to work in win32 mode, but not in x64 mode.
    Getting it to work in x64 is a lot of work (too much).
    Note: I use visual studio c++ 2010 express.
    Yannick also showed me how to run python scripts, so I will proceed in that direction.
    Python and Internet is straightforward.
