Yannick: ViewportSelect documentation
On 16/01/2014 at 11:42, xxxxxxxx wrote:
Cinema 4D Version: 15
Platform: Windows ; Mac ;
Language(s) :---------
Yannick,
There's some typos in the examples for this class.infopoint = viewportselect.GetPixelInfoPoint(x, y)
Should be
infopoint = ViewportSelect.GetPixelInfoPoint(x, y)I'm also having a hard time getting ViewportSelect to work.
It's giving me this error: TypeError: 'c4d.PolygonObject' object is not iterable
ViewportSelect is working fine for me in C++. But not in Python.Example:
#This is a python script that gets the mouse's position with a radius option for making selections #The radius helps you to select things without having to be exactly on the thing you're trying to select #Put the code in a pytag import c4d def main() : obj = op.GetObject() #The object the pytag is on(converted to editable) radius = 10 #Change the radius value as desired radSqr = radius * radius if radSqr < 1.0: return False msg = c4d.BaseContainer() while c4d.gui.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, msg) : if msg[c4d.BFM_INPUT_VALUE] == 0: break mouse_x = msg[c4d.BFM_INPUT_X] mouse_y = msg[c4d.BFM_INPUT_Y] #Get the dimensions of the editor window(this includes the left and top icon borders too) bd = doc.GetActiveBaseDraw() dimension = bd.GetFrame() dimension["cl"], dimension["ct"], dimension["cr"], dimension["cb"] left = dimension["cl"] top = dimension["ct"] right = dimension["cr"] bottom= dimension["cb"] eWinWidth = right - left + 1 #The width of the editor window eWinHeight = bottom - top + 1 #The height of the editor window ##################################################################################### #This code block sets up the radius around the mouse's current position #x1 is amount of screen pixels to check towards the left of the mouse #x2 is amount of screen pixels to check towards the right of the mouse #y1 is amount of screen pixels to check towards the top of the mouse #y2 is amount of screen pixels to check towards the bottom of the mouse ##################################################################################### #Gets the mouseX position - the radius value (but returns 0 if value is less than zero) x1 = int(c4d.utils.Clamp(0, mouse_x - radius, mouse_x - radius)) #Gets the mouseX position + the radius value (but returns the screen width if value is more than the screen width) x2 = int(c4d.utils.Clamp(mouse_x + radius, eWinWidth - 1, mouse_x + radius)) #Gets the mouseY position - the radius value (but returns 0 if value is less than zero) y1 = int(c4d.utils.Clamp(0, mouse_y - radius, mouse_y - radius)) #Gets the mouseY position + the radius value (but returns the screen height if value is more than the screen height) y2 = int(c4d.utils.Clamp(mouse_y + radius, eWinHeight - 1, mouse_y + radius)) ##################################################################################### vps = c4d.utils.ViewportSelect() vps.Init(eWinWidth, eWinHeight, bd, obj, c4d.Mpoints, True, c4d.VIEWPORTSELECTFLAGS_0) #Loop through the pixels in the screen in a matrix like fashion #By getting the pixels using Rows & Columns using 2 for loops for x in range(x1, x2) : for y in range(y1, y2) : rSqrDist = (x - mouse_x)*(x - mouse_x) + (y - mouse_y)*(y - mouse_y) if rSqrDist > radSqr: continue infopoint = vps.GetPixelInfoPoint(x, y) if infopoint.op == obj: #This code will select the points on the object if they're within the radius range bs = c4d.BaseSelect() bs = obj.GetPointS() bs.Select(infopoint.i)
Any idea why it works in C++ but not in Python?
My C++ code is almost identical to this Python code. Except that it's used in a tool plugin.-ScottA
On 16/01/2014 at 14:12, xxxxxxxx wrote:
Never mind. I found the problem.
In C++ we use a polygon type object in the vps.Init() params.
But in Python you guys changed it to require a list of active objects instead.-ScottA
But in Python you guys changed it to require a list of active objects instead.In C++ there are 2 methods Init() in ViewportSelect:
One that takes an object only (BaseObject) and one that takes a list of objects (AtomArray).
On 17/01/2014 at 08:24, xxxxxxxx wrote:
Yeah. That's what tripped me up for a second.
Apparently the Python version doesn't allow us to use a single object in the params. like C++ does.-ScottA
