On 15/01/2014 at 16:32, xxxxxxxx wrote:
User Information: Cinema 4D Version: R12 Platform: Mac ; Mac OSX ; Language(s) : C++ ;
--------- Is there an issue with R12 (32bit) C++ projects with Xcode 4.4.1 and Mavericks?
All my R12 plugin projects stopped compiling and the only change on my machine was the Mavericks upgrade. R15 projects compile fine.
Essentially, when I start building an R12 project it will get stuck while "Creating Universal Binary".
Thanks
Peter
On 15/01/2014 at 17:00, xxxxxxxx wrote:
I just tried to compile the R12 SDK and that does work so it seems to be in my projects. Since all my projects are cloned from the SDK I have no idea to start looking. Any input is greatly appreciated.
On 15/01/2014 at 18:01, xxxxxxxx wrote:
Ok, I ended up creating new projects using the C4DSDK project file. That made it work. Still would like to know what happened there.
On 16/01/2014 at 00:42, xxxxxxxx wrote:
Originally posted by xxxxxxxx <ADDRESS> User Information: Cinema 4D Version: R12 Platform: Mac ; Mac OSX ; Language(s) : C++ ; --------- </ADDRESS> Is there an issue with R12 (32bit) C++ projects with Xcode 4.4.1 and Mavericks? All my R12 plugin projects stopped compiling and the only change on my machine was the Mavericks upgrade. R15 projects compile fine. Essentially, when I start building an R12 project it will get stuck while "Creating Universal Binary". Thanks Peter
Please note that the BaseSDK (OS X 10.5) used in R12 probably might not be available on Mavericks anymore (it ain't by default unless it is there from an old OS/Xcode installation or if you copied it manually on your system). Also the default compiler (gcc 4.2) used in R12 ain't available anymore in Xcode 4.4.
Best regards,
Wilfried
