On 30/12/2013 at 09:17, xxxxxxxx wrote:
Hello all, hope you had some happy holidays.
I'm currently working with an object generator plugin that should be returning a spline. I've done a decent about of work with generator plugins so I feel like I know them pretty well, but I haven't had any of them return splines.
So I always use GetVirtualObjects() but the Py-DoubleCircle example uses GetContour(), and GetVirtualObjects() returns polygonal objects whereas GetContour()returns splines. So it seems that I should be using that.
But then my problem is that I want to use the AddDependence
() stuff, to hide the children and use for updates. By my understanding that could only be used in GetVirtualObjects() because it passes you HierarchyHelp.
Am I on the right track with this at all?
Thanks, Dan
