Add Filename to GeDialog
  • On 26/12/2013 at 18:54, xxxxxxxx wrote:
    Hello everybody,
    sorry for that stupid question, but how can I add a FilenameElement (like UserData/Filename) to a GeDialog. I didn´t find anything in SDK.
    Thanks alot
    rown
  • On 27/12/2013 at 02:27, xxxxxxxx wrote:
    There is a filename customgui, you can examine it with the ressource editor plugin. You can also use just storage.SaveDialog().
    happy holidays,
  • On 03/01/2014 at 13:33, xxxxxxxx wrote:
    Hello littledevil,
    thx for your reply. It was really helpfull.
    Ive solved it in this way:
    from c4d import gui
    class Dlg(gui.GeDialog) :
      TEXT = 10001
      SAVE = 10002
      PATHSTRING = 10003
      OK = 20001
      CANCEL = 20002
      def CreateLayout(self) :
          self.GroupBegin(0, c4d.BFH_SCALEFIT, cols=1)
          self.AddEditText(self.TEXT, c4d.BFH_LEFT, initw=500)
          self.GroupEnd()
          self.GroupBegin(0, c4d.BFH_SCALEFIT, cols=2)
          self.AddEditText(self.PATHSTRING, c4d.BFH_SCALEFIT)
          self.AddButton(self.SAVE, c4d.BFH_LEFT, initw=30, name="...")
          self.GroupEnd()
          self.GroupBegin(2, c4d.BFH_SCALEFIT, cols=2)
          self.AddButton(self.OK, flags=c4d.BFH_SCALEFIT, name="OK")
          self.AddButton(self.CANCEL, flags=c4d.BFH_SCALEFIT, name="CANCEL")
          self.GroupEnd()
      def Command(self, id, msg) :
          if id == self.SAVE:
              path = c4d.storage.SaveDialog(type=c4d.FILESELECTTYPE_ANYTHING, title="Export", force_suffix="txt")
              if path is None: file = ""
              self.SetString(self.PATHSTRING, path)
          if id==self.OK:
              text = self.GetString(self.TEXT)
              path = self.GetString(self.PATHSTRING)
              file = open(path, "w")
              file.write(text)
              file.close
              self.Close()
          if id==self.CANCEL:
              self.Close()
    def main() :
      dlg = Dlg()
      dlg.Open(c4d.DLG_TYPE_MODAL, xpos=550, ypos= 200, defaultw=300, defaulth=10)
    if __name__=='__main__':
    Greetings
    rown
