[Melange] Link issue on Mac OSX 10.7.5
On 20/12/2013 at 09:10, xxxxxxxx wrote:
Cinema 4D Version:   R15
Platform:      Mac OSX  ;
Language(s) :
Melange version : V6_86243
Hi again,
When trying to link Melange (_melange/lib/OSX/_melange_lib_release.a) against my own code on Mac OSX 10.7.5 I get link errors because two symbols are undefined on architecture x86_64 :
_AudioGetHostClockFrequency referenced from _melange_::GeGetTimer()
_AudioGetCurrentHostTime referenced from _melange_::GeGetTimer()
It seems that Melange is calling system functions that are indeed in HostTime.
However I cannot figure out which system library I should link against
(I acknowledge I am no MacOS expert...)
Did anyone have this problem before? how could you fix it?
Thanks!
On 20/12/2013 at 09:45, xxxxxxxx wrote:
Hi beneon,
unfortunately I can't reproduce your problem (building the commandline Example using XCode that is
included with the Melange SDK). Does that one build fine for you?
Best,
-Niklas
On 20/12/2013 at 10:05, xxxxxxxx wrote:
Hi Niklas,
Thanks for the answer. I was able to build commandline on my platform.
When I remove the Core.Audio framework from the list, I get analog link errors as I had before.
I must therefore find a way to add this framework to my solution.
On 20/12/2013 at 10:26, xxxxxxxx wrote:
Problem is solved, thanks Niklas for your help.
