On 08/12/2013 at 23:21, xxxxxxxx wrote:
User Information: Cinema 4D Version: R15 Platform: Windows ; Language(s) :
--------- I have a HDR 32 bit texture layer and now I want to read the color values. For normal 8 bit textures this is not a problem, but how to get the 32 bit color values. Here is my attempt:
Float buffer[3]; //one pixel is 1 float (4 bytes) * 3 (RGB) = 3 floats //get one pixel to test pLayerBmp->GetPixelCnt(0,0,1,(UChar* )buffer,COLORMODE_RGBf, PIXELCNT_0); GePrint("Before pixel 0,0: " + String::FloatToString(buffer[0]) \+ " - " + String::FloatToString(buffer[1]) + " - " + String::FloatToString(buffer[2]));
On 09/12/2013 at 02:49, xxxxxxxx wrote:
Solved. Float buffer[3]; should be Float32 buffer[3];
On 09/12/2013 at 03:16, xxxxxxxx wrote:
In the C4D C++ SDK, defined 'generic' types usually default to the 64-bit version (Float = Float64, Vector = LVector, etc.).
On 12/12/2013 at 08:28, xxxxxxxx wrote:
Ok, good to know.
