ShowPopupDialog
On 28/11/2013 at 11:01, xxxxxxxx wrote:
Hey,
I try to create a PopUp Menu like the default from cinema - with more menus around the mouse position
i get a single menu item but can`t get a second menu item. has one a short example ?
Thanks
On 28/11/2013 at 13:42, xxxxxxxx wrote:
post your code, there is an extensive example in the sdk under gui.ShowPopUpDialog()
On 28/11/2013 at 13:53, xxxxxxxx wrote:
i get a popup with one menu
menu = c4d.BaseContainer() functionsmenu = c4d.BaseContainer() functionsmenu.SetString(1, 'men'); functionsmenu2 = c4d.BaseContainer() functionsmenu2.SetString(1, 'men 2'); menu.SetContainer(IDM_FUNCTIONSMENU, functionsmenu) menu.SetContainer(IDM_GROUPMENU, functionsmenu2) result = gui.ShowPopupDialog(cd=None, bc=menu, x=c4d.MOUSEPOS, y=c4d.MOUSEPOS, flags=c4d.POPUP_CENTERVERT|c4d.POPUP_EXECUTECOMMANDS)
On 28/11/2013 at 15:01, xxxxxxxx wrote:
The documentation shows to use BaseContainer.InsData(), not any of the setter methods.
Best,
-Niklas
On 28/11/2013 at 15:55, xxxxxxxx wrote:
the example show it with SetStrings
http://www.maxonexchange.de/sdk/CINEMA4DPYTHONSDK/help/modules/c4d.gui/index.html?highlight=popup#c4d.gui.ShowPopupDialogmy problem is not to add a submenu - my problem is i like to add more than the one menu at the time - like the cinema default popup menu
On 29/11/2013 at 04:10, xxxxxxxx wrote:
your code is technically correct, on which c4d version are you ? for me the code does run just fine
in r14/15 . are you sure that your container ids are properly set / unique ?
On 29/11/2013 at 04:25, xxxxxxxx wrote:
i use R15 -
right is the menu i get - it work - but is not what i want :)
_<_img src="http://hantmade.com/wp-content/uploads/c4d_plugincafe.png" height="443" width="453" border="0" /_>_
On 29/11/2013 at 05:35, xxxxxxxx wrote:
hm,
I am not quite sure what you mean with 'what I want'. here is a small and recursive example
building a menu tree.import c4d import random from c4d import gui #Welcome to the world of Python def main() : cid, menu = getMenueContainer(c4d.FIRST_POPUP_ID, 0, 3, 8) result = gui.ShowPopupDialog(None, menu, c4d.MOUSEPOS, c4d.MOUSEPOS, c4d.POPUP_CENTERVERT|c4d.POPUP_EXECUTECOMMANDS) def getMenueContainer(cid, curdepth, maxdepth, maxitems, root = c4d.BaseContainer()) : """ """ if curdepth <= maxdepth: children = [] for i in xrange(random.randint(1, maxitems)) : item = c4d.BaseContainer() item.SetString(1, 'Item_{0}'.format(i)) cid, item = getMenueContainer(cid, curdepth + 1, maxdepth, maxitems, item) cid += 1 root.SetContainer(cid, item) return cid, root if __name__=='__main__': main()
On 29/11/2013 at 05:38, xxxxxxxx wrote:
Hey Littledevil,
thanks for that code - sorry for my bad description
I don`t mean to get a tree menu i like to get a menu with more than one menus - a round that mouse position - like the default popup menu in cinema (get it with "v")
On 29/11/2013 at 05:52, xxxxxxxx wrote:
Ah ok. You are talking about the pie menus. Unfortunately they are not exposed in python
(and I think they aren't in cpp too). You would have to write your own system and open
several borderless GeDialogs simultaneously and then render the 'button content' into these
dialogs with a GeUserArea (for example nikklas button thingy class). Has always been on my
'would be fun to do' list, but i never managed to get to it, so I am not sure if it is possible.
