On 20/11/2013 at 05:06, xxxxxxxx wrote:
User Information: Cinema 4D Version: R13 Platform: Windows ; Language(s) : C++ ;
--------- I'm trying to read all descIDs from the base container of an object, but I can't get those from obase.res file. This is the code I'm using:
BaseContainer* pbc = pObj->GetDataInstance(); if (!pbc) return nrProperties;
BaseContainer bc; LONG nrProperties = 0;
for (LONG id, idx = 0; (id = pbc->GetIndexId(idx)) != NOTOK; idx++) { AutoAlloc<Description> desc; if ((desc) && (pObj->GetDescription(desc, DESCFLAGS_DESC_0))) { BaseContainer* pdbc = desc->GetParameterI(id, NULL); if (pdbc) { if (!pdbc->GetBool(DESC_HIDE)) { bc.SetLong(T_OBJ_PROPERTY_ID + nrProperties, id); bc.SetString(T_OBJ_PROPERTY_NAME + nrProperties, pdbc->GetString(DESC_NAME)); nrProperties++; } } } }
On 20/11/2013 at 07:45, xxxxxxxx wrote:
This is the one I tend to use a lot. Using the SDK Browse() function.
BaseObject *obj = doc->GetActiveObject(); const BaseContainer *objBc = obj->GetDataInstance(); AutoAlloc<Description> desc; if (!desc) return FALSE; if (!obj->GetDescription(desc, DESCFLAGS_DESC_0)) return FALSE; DescID dcid, groupid; void *handle = desc->BrowseInit(); if (!handle) return FALSE; //We will store the description values in this variable GeData d; while (desc->GetNext(handle, &objBc, dcid, groupid)) { if (objBc) { String name = objBc->GetString(DESC_NAME); //The text in the GUI for each Gizmo (like the .str file works in plugins) GePrint(name); String ID = objBc->GetString(DESC_IDENT); //The description's ID# expressed in text form GePrint(ID); obj->GetParameter(DescID(dcid), d, DESCFLAGS_GET_0); //Get all the description values and store them in variable "d" //Now we need to check the "d" variable for the specific type of data each description can store Real rValue = d.GetReal(); LONG lValue = d.GetLong(); String sValue = d.GetString(); GePrint("RealValue: " +RealToString(rValue) + " , " + "LongValue: " +LongToString(rValue) + " , " + "StringValue: " +sValue); } } desc->BrowseFree(handle); //Free the memory used by the Browse function
