On 14/11/2013 at 16:30, xxxxxxxx wrote:
User Information: Cinema 4D Version: 13 Platform: Language(s) : C++ ;
--------- well , I'm trying to compile my project using nvcc compiler "nvidia compiler to compile CUDA"
normally in any project the Nvidia CUDA can compile any .cu file "containing any C++ data"
so it is like: nvcc myfile.cu -o myfile
2 things happened: after a long testing , it compiled with a very lot of warnings , most of them in valotile and enums in c4d_gui.h and some other files, but simply cinema4d didn't start.... "hanged in plugin initialization"
also if I include "cuda.h" after "c4d.h" it doesn't compile
thanks
On 14/11/2013 at 23:15, xxxxxxxx wrote:
Compile your .cu files with the CUDA compiler, .cpp files with MSVC. The linker will do the rest.
Best, -Niklas
On 15/11/2013 at 02:47, xxxxxxxx wrote:
I did that , but what I need to know which dependencies are done in the c4d SDK project , as what I did is copy processor definitions from C/C++ to CUDA C/C++ as it was raising "can't find c4d.h , can't find pthread.h ... and so on"
On 15/11/2013 at 03:32, xxxxxxxx wrote:
here is the problematic warning!! warning MSB8012: TargetPath(D:\MAXON\c4dr13\plugins\cinema4dsdk\\cinema4dsdk.dll) does not match the Linker's OutputFile property value (D:\MAXON\c4dr13\plugins\cinema4dsdk\cinema4dsdk.cdl64). This may cause your project to build incorrectly. To correct this, please make sure that $(OutDir), $(TargetName) and $(TargetExt) property values match the value specified in %(Link.OutputFile).
On 15/11/2013 at 03:46, xxxxxxxx wrote:
I fixed this warning by changing target extension from .dll to .cdl64 , but still cinema4d hangs once it tries to load the plugin
On 15/11/2013 at 03:51, xxxxxxxx wrote:
all warnings now of this kind: warning : multicharacter character literal (potential portability problem
On 16/11/2013 at 06:58, xxxxxxxx wrote:
well the only solution was to separate cuda.h from c4d.h , and everything is fine now
