On 08/11/2013 at 12:15, xxxxxxxx wrote:
Using python how can I get a list of objects in the assignment tab of a material
This is where I'm at:
myMat = doc.GetActiveMaterial() Olink = myMat[c4d.MATERIAL_PAGE_ASSIGNMENT] print Olink
However it just returns None.
Any help is appreciated!
On 08/11/2013 at 21:32, xxxxxxxx wrote:
Hi, Man, Iam glad you posted that cause i had problems in r13 with the ### python sdk , I spent tree days trying to make MatAssignData.GetObject(index, doc) in r13 sdk to work aand by luck I think I read R15 SDK and FOUND MatAssignData.ObjectFromIndex(doc, Index) which is WORKING, that was I thought at first, but it only returns the texture tag only.
so here the code, the trick is to use c4d.ID_MATERIALASSIGNMENTS not c4d.MATERIAL_PAGE_ASSIGNMENT.
import c4d from c4d import * #HOPE SOMEONE WILL EXPLAIN!!!! def main() : myDoc=documents.GetActiveDocument() myMat = doc.GetActiveMaterial() Olink = myMat[c4d.ID_MATERIALASSIGNMENTS] myCount = Olink.GetObjectCount() for i in xrange(myCount) : print i, " : ", Olink.ObjectFromIndex(myDoc,i)
If you are a C++, you can try to port this code to python BaseMaterial *mat = doc->GetActiveMaterial(); if(!mat) return TRUE; GeData d; if(mat->GetParameter(DescLevel(ID_MATERIALASSIGNMENTS),d,0)) { MatAssignData *mad = (MatAssignData* )d.GetCustomDataType(CUSTOMDATATYPE_MATASSIGN); if(mad) GePrint("found it"); GePrint(LongToString(mad->GetObjectCount())+" objects"); }
Have a nice week-end!
On 09/11/2013 at 08:24, xxxxxxxx wrote:
**Python version **
#This script lists all the objects that are listed in a materials "Assignment" option import c4d def main() : myMat = doc.GetActiveMaterial() ObjLink = myMat[c4d.ID_MATERIALASSIGNMENTS] #The object Assignment option in the material myCount = ObjLink.GetObjectCount() for i in xrange(myCount) : tag = ObjLink.ObjectFromIndex(doc,i) #Gets the tag that's on the object obj = tag.GetObject().GetName() #Gets the object the texture tag is attached to print obj, tag if __name__=='__main__': main()
C++ version **
//This is an example of getting all the objects that are listed in the material's Assignment link list #include "customgui_matassign.h" BaseMaterial *mat = doc->GetActiveMaterial(); if(!mat) return TRUE; GeData d; if(mat->GetParameter(DescLevel(ID_MATERIALASSIGNMENTS), d, DESCFLAGS_GET_0)) { MatAssignData *mad = (MatAssignData* )d.GetCustomDataType(CUSTOMDATATYPE_MATASSIGN); LONG count = mad->GetObjectCount(); //The number of objects assigned this material for(LONG i=0; i<count ; i++) { BaseTag *tag = (BaseTag* )mad->ObjectFromIndex(doc,i); //Gets the tag that's on the object BaseObject *obj = tag->GetObject(); //Gets the object the texture tag is attached to String objName = obj->GetName(); //Gets the names of the objects in the material's Assignment list GePrint(objName); } }
On 09/11/2013 at 13:22, xxxxxxxx wrote:
@ScottA,
stupid Me, yes that the way to solve it. But according to sdk, ObjectFromIndex(doc,i) must return object list no tag list.
So Thanks a lot for submitting your solution.
On 11/11/2013 at 19:18, xxxxxxxx wrote:
Thanks for the help guys! This got me what I needed. Also I found out this is the same code that you should use to get any data from an inexclusion list.
Thanks again!
On 27/02/2017 at 08:41, xxxxxxxx wrote:
I need the same thing in XPresso(python node). I am new in python. I need to get a list of objects from the assignment tab of a material.
On 28/02/2017 at 02:12, xxxxxxxx wrote:
Originally posted by xxxxxxxx I need the same thing in XPresso(python node). I am new in python. I need to get a list of objects from the assignment tab of a material.
Hi and Welcome to the forums!
Why do you need to access a material assignment from a Python XPresso node? It's not recommended to change the active document from such a node. A Python XPresso node should only manipulate its input data to produce its output(s).
Please create a new topic if you have more questions.
