On 03/11/2013 at 18:27, xxxxxxxx wrote:
User Information: Cinema 4D Version: R15 Platform: Mac OSX ; Language(s) : C++ ;
--------- This is a strange one.
As I upgraded to C4D R15 recently I moved all (three) of my plugins in progress from R12 to the new version by plugging my code into a c4dsdk template. All of them compiled fine. All of them worked in R15.
Today, I am starting to get linker errors. For a test I tried to compile the c4dsdk project and got the same errors (see below). I don't quite know where to start trouble shooting.
The only factor so far is I have been using xCode4 but when XCode5 came out I installed that also.
But I am not quite sure what the "Undefined symbols" error means in the context.
Or could the problem be somewhere in the C4D files?
Thanks
Peter
Undefined symbols for architecture x86_64: "GeUserArea::DrawSetTextCol(Vector64 const&, int)", referenced from: Function2::DrawCell(void*, void*, void*, int, DrawInfo*, GeData const&) in activeobject.o "VectorToHPB(Vector64 const&)", referenced from: LookAtCamera::Execute(BaseTag*, BaseDocument*, BaseObject*, BaseThread*, int, EXECUTIONFLAGS) in lookatcamera.o "GetCustomDataTypeDefault(int)", referenced from: LookAtCamera::GetDDescription(GeListNode*, Description*, DESCFLAGS_DESC&) in lookatcamera.o "TagData::GetModifiedObjects(BaseTag*, BaseDocument*, BaseObject*&, int&, Matrix64 const&, double, int, BaseThread* )", referenced from: vtable for LookAtCamera in lookatcamera.o "AutoBitmap::AutoBitmap(String const&, double)", referenced from: RegisterLookAtCamera() in lookatcamera.o "TreeViewFunctions::PythonCleanup(void*, void* )", referenced from: vtable for Function2 in activeobject.o vtable for MyTreeViewFunctions in layershaderbrowser.o ld: symbol(s) not found for architecture x86_64 clang: error: linker command failed with exit code 1 (use -v to see invocation)
On 04/11/2013 at 13:54, xxxxxxxx wrote:
Did you make sure you cleaned the api project (so any dependencies of the sdk project) before recompiling?
On 04/11/2013 at 15:19, xxxxxxxx wrote:
Thanks, Good point. I didn't do that but then I wasn't able to successfully build any of the projects - which had all compiled before. Earlier today I deleted and re-installed my Xcode 4.4.1 folder and without a problem the builds succeed again.
