On 01/11/2013 at 11:32, xxxxxxxx wrote:
User Information: Cinema 4D Version: r14 Platform: Language(s) : C++ ;
--------- Hi, i can't find the definitions for the spline deformer object. can someone point me to them?
MGSPLINEWRAPDEFORMER_AXIS for example
thanks in advance, Ello
On 01/11/2013 at 11:42, xxxxxxxx wrote:
C4D/modules/mograph/res/description/omograph_splinewrap.h
Best, -Niklas
so, this is something that is not always available in cinema, right?
On 01/11/2013 at 12:00, xxxxxxxx wrote:
ah, ok. i see. it is now part of the core. but where is Omograph_splinewrap defined? i've included omograph_splinewrap.h but get an error for an undeclared inentifier 'Omograph_splinewrap'
any ideas?
On 01/11/2013 at 12:12, xxxxxxxx wrote:
It isn't defined. Grab a Spline Wrap deformer, ask for its type and add the definition in your source code.
> #include <c4d.h> > #include <omograph_splinewrap.h> > > > enum { > Omograph_splinewrap = 1019221, > }; > > > // ...
On 01/11/2013 at 12:16, xxxxxxxx wrote:
thank you very much
On 26/06/2014 at 08:02, xxxxxxxx wrote:
Originally posted by xxxxxxxx It isn't defined. Grab a Spline Wrap deformer, ask for its type and add the definition in your source code. > #include <c4d.h> > #include <omograph_splinewrap.h> > > > enum { > Omograph_splinewrap = 1019221, > }; > > > // ... Best, -Niklas
Niklas can i ask you a couple of questions about the above:
How does the #include <omograph_splinewrap.h> know where to find it? Would that imply setting the mograph folder up as an Additional Include Directory inside the Properties in VisualStudio? Or am i missing something obvious?
Why are u using these brackets <> around the include as opposed to "" is there any difference?
Thanks..
On 26/06/2014 at 09:40, xxxxxxxx wrote:
Hi Eclektrik,
most paths that contain resource description files are already added to the Include Directories of the _api or cinema4dsdk project files. You can manually add the path to the Mograph description resource directory.
When using "", the compiler will first take a look into the parent folder of the current file and then search all other specified paths. <> will only search those paths but also built-in headers which must not necessarily exist as files.
See http://stackoverflow.com/questions/1367316/include-and-include
On 27/06/2014 at 03:35, xxxxxxxx wrote:
Thanks for the replies Niklas much appreciated.
