GeRayCollider
  • On 29/10/2013 at 07:39, xxxxxxxx wrote:
    I used the function GeRayCollider() in a plugin. But I have a few problems.
    First I created a cube.
    Then I  tried to initialize the ray collider with this cube.
    But I got an error message, that the argument must be a polygon object.
    So I tried to convert the cube to a polygonobject.
    I used a call command for this and it works (I can see the polygon object in cinema 4d), but the error message is the same.
    Here ist the code:
    import os, sys
    import time
    import math
    from c4d import plugins
    from c4d import utils
    from config import PLUGIN_ID
    class CommandDataExecute(plugins.CommandData) :
        dialog = None
        #plugin started by user
        def Execute(self, doc) :
            cube = c4d.BaseObject(c4d.Ocube)
            doc.InsertObject(cube)
            cube.SetBit(c4d.BIT_ACTIVE)
            print "Typ: ", cube.GetType()
            c4d.CallCommand(12236)
            ray=c4d.utils.GeRayCollider()
            if not ray.Init(cube) :
                print "Initialisierung nicht erfolgreich"
                start = c4d.Vector(400,0,0)
                end = c4d.Vector(-400,0,0)
                direction = c4d.Vector(-1,0,0)
                length = 800
                print "globale matrix cube: ", cube.GetMg()
                print "radius of the bounding box: ", cube.GetRad()
                does_intersect = ray.Intersect(start, direction, length)
                print "Intersection? ", does_intersect
    Now I have four questions:
    1. Is it necessary to convert the cube to a polygon object?
    2. Is there a better way to convert the cube than using call commands?
    3. Why doesnt the function "ray.Init(cube)" work?
    4. "does_intersect = ray.Intersect(start, direction, length)" should return true. Did I use the function correctly?
    Thanks for your comments.
    Conny
  • On 29/10/2013 at 10:10, xxxxxxxx wrote:
    1. yes
    2. yes two ways - a. grabbing the cache of the object (with is not an option in your scenario) and b. using the SMC method (SendModellingCommand).
    3. The reason is most likely the CallCommand() if you want to use CallCommand() you will have to use the force (Cache) parameter of the method. And even then i wouldn't be so sure if it will work (the usual threading mess with c4ds main thread).
    4. depends on what you were trying to do, but basically yes.
  • On 12/11/2013 at 07:27, xxxxxxxx wrote:
    Thank you. The SMC method works.
    But now I have a problem with the intersection.
    In the following example I created two cubes and for each of them a GeRayCollider (ray1 and ray2).
    ray1 intersects cube 1 in one point. But I get two intersections in the same point.
    Although ray 2 doesn't intersect cube2 I get the same two intersections as with ray1.
    I expected that the function ray2.Intersect() only returns true, if there is an intersection with cube2.
    Can someone explane me that?
    import os, sys
    import time
    import math
    from c4d import documents
        dialog = None
            doc = documents.GetActiveDocument()
           #create two cubes and convert them to polygon objects
            cube1 = c4d.BaseObject(c4d.Ocube)
            cube2 = c4d.BaseObject(c4d.Ocube)
            off = c4d.Vector(-300,0,0)
            v1 = c4d.Vector(1,0,0)
            v2 = c4d.Vector(0,1,0)
            v3 = c4d.Vector(0,0,1)
            matrix=c4d.Matrix(off, v1, v2, v3)
            cube2.SetMg(matrix)
            doc.InsertObject(cube1)
            doc.InsertObject(cube2)
            cube1.SetBit(c4d.BIT_ACTIVE)
            obj=doc.GetActiveObject()
            convert=c4d.utils.SendModelingCommand(command=c4d.MCOMMAND_MAKEEDITABLE , list=[obj], mode= c4d.MODELINGCOMMANDMODE_ALL, bc= c4d.BaseContainer(), doc = doc)
            doc.InsertObject(convert[0])
            cube1=convert[0]
            cube2.SetBit(c4d.BIT_ACTIVE)
            cube2=convert[0]
            #create GeRayCollider
            ray1=c4d.utils.GeRayCollider()
            ray2=c4d.utils.GeRayCollider()
            start = c4d.Vector(0,0,-700)
            end = c4d.Vector(0,0,0)
            dir = end - start
            length = math.sqrt(dir.x*dir.x+dir.y*dir.y+dir.z*dir.z)
            direction=dir.GetNormalized()
            print "direction: ", direction
            print "length: ", length
            print "cube1: "
            if not ray1.Init(cube1) :
                does_intersect1 = ray1.Intersect(start, direction, length)
                print "Intersection? ", does_intersect1
                j = ray1.GetIntersectionCount()
                print "Number of Intersections: ", j
                for k in range (0, j, 1) :
                    print "Intersection ",k,": ", ray1.GetIntersection(k)
                print "----------------------------------------------"
                print "cube2: "
            if not ray2.Init(cube2) :
                does_intersect2 = ray2.Intersect(start, direction, length)
                print "Intersection? ", does_intersect2
                j = ray2.GetIntersectionCount()
                    print "Intersection ",k,": ", ray2.GetIntersection(k)
