On 17/10/2013 at 12:52, xxxxxxxx wrote:
Cinema 4D Version: r14
Platform:
Language(s) : C++ ;
I am trying to get the position of a some points between two points. this is how I try to do it, but it doesn't work. somehow the direction is totally weird, as soon as p1Offset and p2Offset are changing:
SplineObject* tempSpline = SplineObject::Alloc(pointCount,SPLINETYPE_LINEAR);
Vector* tempPoints = tempSpline->GetPointW();
for (int i=0;i<pointCount;i++)
Matrix dir= HPBToMatrix(VectorToHPB(p2-p1),ROTATIONORDER_DEFAULT);
Vector perStep = (p2 - Vector(0,p2Offset,0) * dir - p1 + Vector(0,p1Offset,0) * dir) / pointCount;
tempPoints[i] = p1 + Vector(0,p1offset,0) * dir + (i + 0.5) * perStep;
the simple distribution of the points between p1 and p2 work with no problem while p1Offset and p2Offset are zero. what i want to do is to be able to set a distance from p1 / p2 so the points distribute between those two offseted points.
i am quite sure it has something to do with how i calculate the direction
would be cool, if someone could have a look and tell me what I am doing wrong.
cheers,
Ello
