On 14/10/2013 at 02:27, xxxxxxxx wrote:
I want to set the Load Bitmap option of a Doodle Object. I can do that by using a CallButton, but then the user has to select a bitmap. I want to do it automatically, so set the bitmap using python.
Looking at the Doodle Object, it seems a hidden Tag is connected to the object, storing all the information(?).
<c4d.BaseTag object called 'Doodle Image/Doodle Image' with ID 1022211 ...>
So it would seem to me that the bitmap information is also stored somewhere in the tag. But where? Below script gave me some information. I searched H and RES files to get more information, but so far I do not get the bitmap information.
Any thoughts?
doodleobj = doc.SearchObject("Doodle Object") bc = doodleobj.GetDataInstance() link = bc.GetLink(1002) print link if (link) : print link print "name:", link[c4d.ID_BASELIST_NAME] print "link:", link[c4d.DOODLEOBJECT_IMAGE] print link.GetType()
On 14/10/2013 at 22:36, xxxxxxxx wrote:
This is unfortunately not possible. The bitmap is stored in an internal member of the tag. Bitmaps can not be stored in containers.
Best, -Niklas
On 15/10/2013 at 03:04, xxxxxxxx wrote:
Ok, thanks.
On 24/10/2013 at 01:38, xxxxxxxx wrote:
Well, in theory, you could implement a CustomDataType that holds a Basebitmap. That way, you could put it into a BaseContainer. But I'd say: too much work for too little benefit.
