Port Creation
On 03/10/2013 at 08:59, xxxxxxxx wrote:
Cinema 4D Version: 14.038
Platform: Windows ;
Language(s) : PYTHON ;---------
I'm working on a script that creates nodes in XPresso and ran into a snag. I cant seam to get the GV_OBJECT_OPERATOR_OBJECT_OUT to work. So far all the other nodes create just fine.What I want is the object node Object Out port to connect to a point node Object In port.
Ive tried using the .SetPortType to change a port that will create into the object port. However I'm not sure im setting it up correctly.
node_obj1.SetPortType(c4d.GV_PORT_OUTPUT, c4d.GV_OBJECT_OPERATOR_OBJECT_OUT)
Any help would be great!
Let me know if I'm not explaining myself well enough.
On 07/10/2013 at 08:53, xxxxxxxx wrote:
Ok so here is an example I am able to show. using a null as a selection run this script:
import c4d from c4d import gui #Welcome to the world of Python def main() : # Create Tag tag = c4d.BaseTag(c4d.Texpresso) # Add Tag op.InsertTag(tag) #Get the node master of selected xpresso tag nm = op.GetFirstTag().GetNodeMaster() #Create the object's node node1 = nm.CreateNode(nm.GetRoot(),c4d.ID_OPERATOR_OBJECT,insert=None, x=20, y=20) node2 = nm.CreateNode(nm.GetRoot(),c4d.ID_OPERATOR_POINT,insert=None, x=20, y=70) # Create Ports pObjOut = node1.AddPort(c4d.GV_PORT_OUTPUT, c4d.GV_OBJECT_OPERATOR_OBJECT_OUT) pNorOut = node2.AddPort(c4d.GV_PORT_OUTPUT, c4d.GV_POINT_OUTPUT_NORMAL) # Test Ports print pObjOut print pNorOut return None if __name__=='__main__': main()
You will see that It will print none for the object port but for the output of the point node normal a port is created.
How can I get this Object Out port to work?
On 08/10/2013 at 07:24, xxxxxxxx wrote:
So I found a way to bypass the Object Out port not working by adding a userdata Link. THis is what it looks like after the script is run:
_<_img src="http://shawnfrueh.com/references/c4d/nodebroken.png" height="371" width="509" border="0" /_>_
As you can see something is not right. So I did a little R&D and found that creating the port itself through python breaks the object node. I can drag and drop the Spline object into XPresso and add the user data manually like this:
<_<_img src="http://shawnfrueh.com/references/c4d/nodeworking.png" height="371" width="509" border="0" /_>_" />
Everything works fine then.
This is the code I used to create the port that then breaks the node:
objPort = node_obj1.AddPort(c4d.GV_PORT_OUTPUT,(c4d.ID_USERDATA,1),message=True)
Am I setting up the .AddPort wrong?
On 08/10/2013 at 14:06, xxxxxxxx wrote:
Hi.
I had this problem recently and found something on the web that should do the trick:objPort = node_obj1.AddPort(c4d.GV_PORT_OUTPUT, c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA, c4d.DTYPE_SUBCONTAINER, 0), c4d.DescLevel(1)), message=True)
Where the id of the userdata is described with "c4d.DescLevel(1)" for the first userdata. As I said I found it on the web and I don't quite get it myself, but it seems to work.
Phil
On 08/10/2013 at 14:44, xxxxxxxx wrote:
Thanks Phil! That did the trick! I appreciate the help.
