make UserData in C++
On 02/09/2013 at 21:14, xxxxxxxx wrote:
Cinema 4D Version: R12
Platform: Mac ;
HiIs it possible to add User Data (as in the User Data tab of the Attributes window) to an object that is created in my code? I guess you use GetDynamicDescription to access existing User Data.
Thanks
Peter
On 03/09/2013 at 01:02, xxxxxxxx wrote:
Exactly. You can use DynamicDescription::Alloc(), passing the user-data's description as a
BaseContainer, to append a new user-data parameter. The description ID of the new parameter
will be returned.
On 04/09/2013 at 13:34, xxxxxxxx wrote:
Thanks NiklasR
I am currently trying to find example code and wading through the docs to find how to actually do this.
My understanding is a bit nebulous at this point.Peter
On 04/09/2013 at 13:50, xxxxxxxx wrote:
Bool AddShaderField(BaseObject* op) {
String name = GeLoadString(IDS_SHADERCOLLECTION_ADDSHADERDEFAULTNAME);
Bool success = RenameDialog(&name);// Break if the rename dialog was canceled.
if (!success) {
return TRUE;
}// Create a cusotm datatype container.
BaseContainer container = GetCustomDataTypeDefault(DTYPE_BASELISTLINK);
container.SetString(DESC_NAME, name);
container.SetString(DESC_SHORT_NAME, name);
container.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_TEXBOX);// Obtain the object's user-data description.
DynamicDescription* desc = op->GetDynamicDescription();
if (!desc) {
MessageDialog(GeLoadString(IDS_SHADERCOLLECTION_ADDSHADERDDERROR, __FILE__, LongToString(__LINE__)));
return FALSE;
}// Create a new UserData entry.
desc->Alloc(container);
return TRUE;
On 04/09/2013 at 16:56, xxxxxxxx wrote:
Thanks. That made it much clearer. The ways of the SDK are often very mysterious to me.
Peter
On 04/09/2013 at 21:16, xxxxxxxx wrote:
And promptly a new question pops up.
How can I create groups? Or, actually I did create a group like this:
bc = GetCustomDataTypeDefault(DTYPE_GROUP); bc.SetString(DESC_NAME, "General"); bc.SetString(DESC_SHORT_NAME, "General"); bc.SetBool(DESC_GUIOPEN, TRUE); bc.SetBool(DESC_TITLEBAR, TRUE); desc->Alloc(bc);
But how to I move my other data into the group?
Do you use DESC_PARENTGROUP, DESC_PARENTID?
On 05/09/2013 at 07:59, xxxxxxxx wrote:
Small example without any error checking stuff:
//This example creates a group UserData item //Then it creates a Real type userData item as a child of the group BaseDocument *doc = GetActiveDocument(); BaseObject *obj = doc->GetActiveObject(); DynamicDescription* dd = obj->GetDynamicDescription(); BaseContainer groupContainer; dd->FillDefaultContainer(groupContainer, DTYPE_GROUP, "New Group"); DescID groupID = dd->Alloc(groupContainer); dd->Set(groupID, groupContainer, obj); BaseContainer realContainer; dd->FillDefaultContainer(realContainer, DTYPE_REAL, "New Real"); GeData dataID; dataID.SetCustomDataType(CUSTOMDATATYPE_DESCID, groupID); realContainer.SetData(DESC_PARENTGROUP, dataID); DescID realID = dd->Alloc(realContainer); dd->Set(realID, realContainer, obj);
On 06/09/2013 at 13:56, xxxxxxxx wrote:
Great. That works although I am not sure I would have come up with it. In retrospect it looks logical.
Thanks
Peter
On 09/09/2013 at 15:38, xxxxxxxx wrote:
And here we go again. I find DynamicDescription dramatically confusing because references to it are all over the place in the documentation. I understand groups now but I am stuck at how to implement a Popup menu. I suppose you use DTYPE_POPUP to make a container for the menu and use DESC_CYCLE to populate it?
On 10/09/2013 at 01:30, xxxxxxxx wrote:
With "Popup menu", do you mean a Cycle field? The elements in a Cycle field are described using a
BaseContainer. Take a look at the documentation of the Description class, all IDs are listed up there
with quite good description.BaseContainer cycle; cycle.SetString(0, "Cycle Value 0"); cycle.SetString(1, "Cycle Value 1"); itemdesc->SetContainer(DESC_CYCLE, cycle);
Best,
-Niklas
On 10/09/2013 at 08:19, xxxxxxxx wrote:
The popup button doesn't seem to work like the ComboButton Nik.
It's either broken. Or the the way we populate it with entries is different.Example that adds a UD ComboButton to the active object:
BaseObject *obj = doc->GetActiveObject(); if (!obj) return FALSE; //Create a list of ComboButton values BaseContainer names; names.SetString(0,"Scott"); names.SetString(1,"Nicklas"); BaseContainer bc = NULL; bc.SetString(DESC_NAME, "My Combo"); bc.SetString(DESC_SHORT_NAME, "My Combo"); bc.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_CYCLEBUTTON); //<--- put CUSTOMGUI_POPUP here and it no longer works!!! bc.SetContainer(DESC_CYCLE, names); //Get the object's master UD container that holds all the UserData entries DynamicDescription *dd = obj->GetDynamicDescription(); if(!dd) return FALSE; //Create a new UserData entry using the container values above dd->Alloc(bc); SendCoreMessage(COREMSG_CINEMA, BaseContainer(COREMSG_CINEMA_FORCE_AM_UPDATE)); //Refresh the AM to see the changes in real time EventAdd();
