On 29/08/2013 at 08:29, xxxxxxxx wrote:
From Python SDK:
Retrieves the intersection, found by GeRayCollider.Intersect(), by index:
intersection = rc.GetIntersection(id) intersect["face_id"] # The polygon index, int intersect["tri_face_id"] # If first half of quad or triangle face_id + 1, else -(face_id + 1), int intersect["hitpos"] # Position of the intersection, c4d.Vector intersect["distance"] # Distance to the intersection, float intersect["f_normal"] # Face normal. (Not normalized.), c4d.Vector intersect["barrycoords"] #Barrycentric coordinates of the intersection. (x = u, y = v, z = d), c4d.Vector intersect["backface"] # True if the intersected face's normal points away from the camera, otherwise False, bool
the intersection to points, is it possible?
On 29/08/2013 at 09:59, xxxxxxxx wrote:
Please clarify your question, nobody knows what you are talking about. An intersection is a point in 3D space, if this is what you mean.
On 29/08/2013 at 10:49, xxxxxxxx wrote:
Hi NiklasR. I would like to move an object and the object must target one of the point of another object
example:
obj = doc.GetActviveObject()
obj_target= doc.GetFirstObject()
I would like to move, with GeRayCollider, obj to obj_target.
My intersection would be a point of obj_target points.
On 29/08/2013 at 11:49, xxxxxxxx wrote:
Hi Runner,
The quote you posted tells you: intersect["hitpos"] # Position of the intersection, c4d.Vector
After you have successfully initialized the GeRayCollider and sent a ray through time and space, you can use GeRayCollider.GetIntersectionId() to retrieve information about one of the intersections the collider figured. The returned value is a dictionary and contains the hit position as the documentation states. import c4d def main() : target = doc.GetFirstObject() if not op or not target: return if not isinstance(target, c4d.PolygonObject) : return c4d.gui.MessageDialog("First object must be a polygon object.") collider = c4d.utils.GeRayCollider() if not collider.Init(target) : return c4d.gui.MessageDialog("GeRayCollider failed to initialize.") bd = doc.GetActiveBaseDraw() cam = bd.GetSceneCamera(doc) cam_mg = cam.GetMg() ray_p = cam_mg.off ray_d = cam_mg.v3 length = 1000000000 does_intersect = collider.Intersect(ray_p, ray_d, length) if not does_intersect: return c4d.gui.MessageDialog("No Intersection found.") inter = collider.GetNearestIntersection() mg = op.GetMg() mg.off = inter["hitpos"] doc.AddUndo(c4d.UNDOTYPE_CHANGE_SMALL, op) op.SetMg(mg) c4d.EventAdd() main()
Usage: Make the first object in the scene editable. Select another object and place the camera so that the center directly points on a polygon on the surface of the first object.
Please note that the documentation (R14.041) is wrong here: The "goal" parameter does not only need to be a BaseObject, it even needs to be a PolygonObject. You can convert any object to a polygon object, there's plenty information here in the fourm.
Cheers, -Niklas
On 29/08/2013 at 13:50, xxxxxxxx wrote:
Thanks NiklasR
but i have have successfully initialized the GeRayCollider, with intersect["hitpos"]...
but my object is positioned of polygon surface...
I want the new op.SetMg(mg) is only points of first object... no surface.... You can only get points from ["hitpos"] library? How?...
On 08/09/2013 at 16:12, xxxxxxxx wrote:
I am sorry, but I can not understand what you are saying. Do you want to calculate "intersections" with points rather than a polygon surface?
Best regards, -Niklas
