On 26/08/2013 at 16:34, xxxxxxxx wrote:
I want to include a BitmapButton in my Object plugin description. Because DescriptionGetBitmap is not implemented in Python, I've used the RegisterIcon method as described in other posts here.
But I still get errors in the console like "AttributeError: Parameter value not accessible (object unknown in Python)" whenever I override NodeData:Message - even if I just override it and immediately return True.
Is there any way to get around this, or do I have to choose between eliminating the BitmapButton or writing a bunch of junk into the console?
On 27/08/2013 at 00:12, xxxxxxxx wrote:
I am not sure if this is related, but BaseContainers return that exception when you do try to access a DTYPE_BUTTON or DTPYE_FILENAME DescLevel. I did stumble over that while trying to iterating over BaseShader containers. I cannot offer a solution except for stepping over these problematic ids, but my point is - the problem could be quite fundamental.
On 27/08/2013 at 10:15, xxxxxxxx wrote:
I'll make you a deal Rick. I'll show you how to add a registered image to your bitmap button. If you show me how to check when that button is pressed. OK?
.pyp
#This is an example of how to add an image to a bitmap button for an object plugin using a custom registered icon #The image should be located in the plugin's res folder import c4d,os import c4d.plugins as plugins from c4d import plugins, utils, bitmaps, gui,documents class CubeGenerator(plugins.ObjectData) : cache = None def Init(self, op) : return True def GetVirtualObjects(self, op, hh) : if not self.cache: self.cache = c4d.BaseObject(c4d.Ocube) return self.cache def Message(self, node, type, data) : #How the frack do you check if the Bitmap Button was pressed!? >:-< return True @ classmethod def Register(cls) : BITMAP_ID = 100000 #Be sure to get a unique ID from PluginCafe.com! buttonimage = bitmaps.BaseBitmap() #We need an instance of BaseBitmap class to use an image path, fn = os.path.split(__file__) buttonimage.InitWith(os.path.join(path, "res", "buttonimage.jpg"))#The location where the button image exists gui.RegisterIcon(BITMAP_ID, buttonimage) #We need to register custom images & icons plugins.RegisterObjectPlugin( **{ 'id': 1000009, #TESTING ID ONLY!!!!! 'str': 'Generator example', 'description': 'Ocubegen', 'info': c4d.OBJECT_GENERATOR, 'icon': buttonimage, #Puts the image in the menu entry 'g': cls, } ) CubeGenerator.Register()
.res
CONTAINER Ocubegen { NAME Ocubegen; INCLUDE Obase; GROUP ID_OBJECTPROPERTIES { BITMAPBUTTON MY_BITMAP { BORDER; ICONID1 100000; } BOOL MY_CHECKBOX{} } }
.h
#ifndef _OCUBEGEN_H_ #define _OCUBEGEN_H_ enum { Ocubegen = 10000, MY_BITMAP, MY_CHECKBOX }; #endif
.str
STRINGTABLE Ocubegen { Ocubegen "Cube Generator"; MY_BITMAP "Bitmap Button"; MY_CHECKBOX "Enabled"; }
On 27/08/2013 at 11:40, xxxxxxxx wrote:
Thanks Scott - I got that far - but do you not get an AttributeError each time the overridden Message method is called?
That's my problem - presumably because DescGetBitmap isn't implemented. Wondering if there's a way around that.
I hadn't even got so far as detecting clicks.
On 27/08/2013 at 11:53, xxxxxxxx wrote:
No. I get no errors with the code I posted. I'm using R13 BTW. Not sure if that makes any difference or not.
Edit- I noticed that if I add the GetDEnabling() method to my plugin I get that error Rick. Not sure why. But that method seems to clash with using a bitmap button for some reason.
On 27/08/2013 at 15:59, xxxxxxxx wrote:
Ah - thanks. For some reason it wasn't happening when I removed Message but it also isn't happening if I leave Message and remove GetDEnabling. Hmm.
So here's my part of the deal:
def Init(self, op) : self.InitAttr(host=op, type=bool, id=[c4d.MY_BITMAP]) return True def Message(self, node, type, data) : if type == c4d.MSG_DESCRIPTION_COMMAND: if data['id'][0].id == c4d.MY_BITMAP: print "BUTTON PRESSED" return True
On 27/08/2013 at 16:39, xxxxxxxx wrote:
Hmmm. Strange. Are you really getting a return from that Message() code? I found the same code snippet in the python docs. But it does not work in my plugin. That code only works for a standard button for me...Not on a bitmap button.
If it's working for you. I'm wondering if it's because I'm using R13?
On 28/08/2013 at 14:28, xxxxxxxx wrote:
Just checked - it's not working in R13, but it does work in R14 and up.
On 28/08/2013 at 15:20, xxxxxxxx wrote:
OK. Thanks for checking on it Rick.
