TraceColor and Reflections
On 19/08/2013 at 09:15, xxxxxxxx wrote:
Cinema 4D Version:   12+
Platform:   Windows  ;
Hy there,
I use TraceColor within a shader to trace reflections. This works fine, as long as there are shaders involved, but it does not work for example to get the colors from a reflecting material (reflection channel used).
So, if I can't determine the reflections with TraceColor, is there another way to do this? Is there another function for reflections? Or do I need to set certain flags to get the correct behavior?
If there is no such function, is there a way to figure out the material settings of the point hit by TraceColor, so I can send out the next ray "manually"? Somehow I can't imagine I need to do that manually, as Cinema for sure has a way to trace reflections...
Thank you,
maxx
On 28/08/2013 at 07:38, xxxxxxxx wrote:
Howdy,
Well, it appears that no one knows.
Adios,
Cactus Dan
On 28/08/2013 at 07:56, xxxxxxxx wrote:
...at least there are now two replies and some movement in the thread 😄
maxx
On 02/09/2013 at 04:11, xxxxxxxx wrote:
Did you have a look at GetSurfaceData()? SurfaceData contains things like reflection color and the reflected ray.
On 02/09/2013 at 09:55, xxxxxxxx wrote:
Thanks for the tip! I really missed this...
With the reflection amount in the SurfaceData, I have the information I need.
maxx
On 02/09/2013 at 15:38, xxxxxxxx wrote:
I found the problem! The ray used for the TraceColor needs its transport vector set to 1... easy, if you know...
maxx
