Suggested way to handle parameter changes
On 08/07/2013 at 03:27, xxxxxxxx wrote:
Cinema 4D Version:   R12-R14
Platform:   Windows  ;
Hi!
In our latest release we replaced some parameters by a single parameter (custom datatype). My question is what is the suggested way to handle such parameter changes to maintain backward and also forward compability (loading of objects saved with old plugin).
Currently I do it like this:
When the latest version of the plugin is loaded I use Read() to set the new parameter by reading the old parameters. Then if the value of the new parameter changes I use SetDParameter() to also set the old parameters to maintain backward compability. Does anyone have a cleaner solution?
Thanks!
Satara
On 08/07/2013 at 03:40, xxxxxxxx wrote:
If you want the old plugin to load scens saved with the new plugin, you must convert the new data
format to the old format when writing to file. When reading, you simply convert it to the new format
and set it to your parameter.
I doubt there's a better solution to this. You'll break the beakwards compatibility in any other case.
Though, if your new parameter contains _additional_ information, you must write this information
on another disklevel.
I'm not sure how Cinema handles the loading of the value from the file since they are written
and loaded automatically so you can not interferre and tell Cinema "wait a sec, that value you
wrote automatically the last time, I want to read it myself this time" or something like this. My
guess is that the value is automatically read and loaded into the container. You could just retrieve
the loaded information, convert it to your new parameter and delete the old information from the
container.
For writing, you need to do the whole thing backwards. So you just fill in the original container IDs
with the values in the old data format and let Cinema automatically write your container. Only
question remaining is _when_ you can do that.. 🙂
Best,
-Nik
On 08/07/2013 at 04:06, xxxxxxxx wrote:
Hey Niklas, thanks for the quick response!
I already tried it like this but as you say the problem is "when" to set the old parameters. While reading of the old parameters works fine, setting of the parameters in Write() does not work.
So I assume when Read() gets called the original BaseContainer is already restored. But it seems to be saved before Write() gets called.
I just checked the docs again and noticed that the DocumentInfoData struct which is passed with MSG_DOCUMENTINFO defines Events like MSG_DOCUMENTINFO_TYPE_SAVE_AFTER and MSG_DOCUMENTINFO_TYPE_LOAD. I think I could use those instead of Read() and Write(). Thanks again for the hint!
