Read MoGraph Selection from Effector plugin
On 23/06/2013 at 02:58, xxxxxxxx wrote:
Cinema 4D Version: R14
Platform:
I can't find a way to read in the MoGraph selection from an EffectorData plugin. I probably miss
something obvious, any hints are appreciated. :)-Niklas
On 23/06/2013 at 05:08, xxxxxxxx wrote:
i don't think effectors contain a pointer / reference to a selection, as that would cause
problems for setups where one effector is targeting multiple generator objects.
long story short:
1. create a generator with a selection.
2. assign an effector to the generator and restrict it to the selection.
3. duplicate the generator.
4. rename the selection tag on the duplicate.the effector will stop working on the duplicate setup after step four. effectors do not do
anything with selections themselves i think, they just do carry arround the name string.
a generator object does relate to that name string when passing the modata to effector
methods.so you have either to stick with the selection name string provided by the effectors
description or you rely on the modata passed to the effector methods, as it will contain
sort of the selection info.
long story short:
sort of the selection info.Well, they contain the name of the MoGraph selection tag which can be grabbed from the MoGraph
generator object in ModifyPoints(). I couldn't find the selection info in the MoData array. But after
taking another deep look into the c4d_baseeffector.h header, I found the
MSG_GET_MODATASELECTION message!// Find the MoGraph selection tag. BaseTag* moTag = NULL; String moTagName = bc->GetString(ID_MG_BASEEFFECTOR_SELECTION); if (moTagName.Content()) moTag = gen->GetFirstTag(); while (moTag) { if (moTag->IsInstanceOf(Tmgselection) && moTag->GetName() == moTagName) { break; } moTag = moTag->GetNext(); } // Retrieve the BaseSelect from the MoGraph selection tag. BaseSelect* moSelection = NULL; if (moTag && moTag->IsInstanceOf(Tmgselection)) { GetMGSelectionMessage data = {0}; moTag->Message(MSG_GET_MODATASELECTION, &data); moSelection = data.sel; }
Thanks for your answer though, I appreciate your effort.
Best,
-Niklas
On 23/06/2013 at 12:25, xxxxxxxx wrote:
I have this very heavily commented Mograph selection example in my notes.
And I found it to be very useful.-The indices of the selected clones are stored in a BaseSelect object in the MoGraph Selection tag. -In C++ the selection is accessed with BaseTag::Message(). -The result is sent to a GetMGSelectionMessage struct, which contains a single BaseSelect member. #include "..\..\..\resource\_api\c4d_baseeffectordata.h" BaseObject *obj = doc->SearchObject("Cloner"); //The cloner object if(!obj) return FALSE; BaseTag *moSelTag = obj->GetTag(Tmgselection,0); //Look for a moselection tag starting from the first tag if(!moSelTag) return FALSE; AutoAlloc<BaseSelect> bs; //Create an empty BaseSelect GetMGSelectionMessage msm = GetMGSelectionMessage(); //Create a struct to hold the tag data moSelTag->Message(MSG_GET_MODATASELECTION, &msm); //Grab the data from the tag and save it in the struct msm.sel->CopyTo(bs); //Copy it to the BaseSelect variable LONG count = bs->GetCount(); //Gets how many clones are currently selected GePrint(LongToString(count)); //Loops through the BaseSelection's index#'s for the selected clones LONG seg=0,a,b; while (bs->GetRange(seg++,&a,&b)) //While searching through the selection's range of elements { for (LONG i=a; i<=b; ++i) //if an element is true(the clone is selected) { GePrint(LongToString(i)); //Print the BaseSelect index# for the selected clone } } //LONG tgl = bs->Toggle(0); //Toggle the first moselection tag's element on/off bs->CopyTo(msm.sel); //Update the struct to reflect the changes made with BaseSelect
