On 11/06/2013 at 23:59, xxxxxxxx wrote:
Is there a way to get the dimensions of a dialog window as it's being resized. I've tried various ways with no luck.
I've tried using a GeUserArea and its various methods but nothing. Might be overlooking something.
Thanks!
On 12/06/2013 at 02:53, xxxxxxxx wrote:
Hi, use a outer group and then use GetDim on that.
Cheers, Seb
On 12/06/2013 at 03:02, xxxxxxxx wrote:
Nice! I will give it a try.
On 14/06/2013 at 09:14, xxxxxxxx wrote:
Why not use GeUserArea.Sized(self, w, h) or drawmsg is called after an re-size with the new dimensions.
GeUserArea.Sized
GeUserArea.DrawMsg(self, x1, y1, x2, y2, msg)[](file:///D:/pgrooff/Documents/pim/c4d/Python%20Help%20R14/help/modules/c4d.gui/GeUserArea/index.html?highlight=drawmsg#GeUserArea.DrawMsg)
GeUserArea.DrawMsg
Called when C4D wants you to draw your userarea. Use the drawing functions to update your user area in the region speicified by the rectangle from (x1,y1) to (x2,y2). Parameters:|
---|--- _<_t_>_
