On 05/06/2013 at 15:24, xxxxxxxx wrote:
Hey,
I have placed my functions to create objects in another file. They get called when a button is pressed. In the same Command-method the objects need to be changed, depending on some sliders.
It all worked fine, untill I replaced my functions. The other files loads properly, the function as well, the objects get created. However, when I change the sliders, the objects won't change.
First it gave an Error that global "L_Foot" isn't defined. Then I defined them again in my main file, and the error was gone, but still the objects won't change.
Here's a snippet of my code:
def Command(self, id, msg) : #Commands if (id == 10002) : #Button Create Character GENDER = self.GetLong(10001) print GENDER doc = c4d.documents.GetActiveDocument() AddLeftFoot(doc) AddRightFoot(doc) AddLeftToes(doc) AddRightToes(doc) AddLeftLeg(doc) AddRightLeg(doc) AddLeftThigh(doc) AddRightThigh(doc) AddHip(doc) AddBody(doc) AddLeftArm(doc) AddRightArm(doc) AddLeftUpperArm(doc) AddRightUpperArm(doc) AddLeftLowerArm(doc) AddRightLowerArm(doc) AddLeftWrist(doc) AddRightWrist(doc) c4d.CallCommand(17105) # Gouraud Shading (Lines) c4d.CallCommand(12148) # Frame Geometry c4d.EventAdd() #Sliders# ######################################################################################################################################################## ### Left_Foot SLiderCode ######################################################################################################################################################## L_Foot = c4d.PolygonObject(8, 6) if id in (FOOT_X_SLIDER, FOOT_Y_SLIDER, FOOT_Z_SLIDER, FOOT_AXIS_X_SLIDER, LEG_X_SLIDER, LEG_Z_SLIDER) : FOOT_X = self.GetReal(FOOT_X_SLIDER) FOOT_Y = self.GetReal(FOOT_Y_SLIDER) FOOT_Z = self.GetReal(FOOT_Z_SLIDER) FOOT_AXIS_X = self.GetReal(FOOT_AXIS_X_SLIDER) LEG_X = self.GetReal(LEG_X_SLIDER) LEG_Z = self.GetReal(LEG_Z_SLIDER) L_Foot.SetPoint(0, c4d.Vector((FOOT_AXIS_X -FOOT_X/2.0), (ZERO), (-LEG_Z/2.0 -(FOOT_Z -LEG_Z) +(FOOT_X -LEG_X)/2.0))) L_Foot.SetPoint(1, c4d.Vector((FOOT_AXIS_X -FOOT_X/2.0), (FOOT_Y), (-LEG_Z/2.0 -(FOOT_Z -LEG_Z) +(FOOT_X -LEG_X)/2.0))) L_Foot.SetPoint(2, c4d.Vector((FOOT_AXIS_X +FOOT_X/2.0), (ZERO), (-LEG_Z/2.0 -(FOOT_Z -LEG_Z) +(FOOT_X -LEG_X)/2.0))) L_Foot.SetPoint(3, c4d.Vector((FOOT_AXIS_X +FOOT_X/2.0), (FOOT_Y), (-LEG_Z/2.0 -(FOOT_Z -LEG_Z) +(FOOT_X -LEG_X)/2.0))) L_Foot.SetPoint(4, c4d.Vector((FOOT_AXIS_X +FOOT_X/2.0), (ZERO), (LEG_Z/2.0 +(FOOT_X -LEG_X)/2.0))) L_Foot.SetPoint(5, c4d.Vector((FOOT_AXIS_X +FOOT_X/2.0), (FOOT_Y), (LEG_Z/2.0 +(FOOT_X -LEG_X)/2.0))) L_Foot.SetPoint(6, c4d.Vector((FOOT_AXIS_X -FOOT_X/2.0), (ZERO), (LEG_Z/2.0 +(FOOT_X -LEG_X)/2.0))) L_Foot.SetPoint(7, c4d.Vector((FOOT_AXIS_X -FOOT_X/2.0), (FOOT_Y), (LEG_Z/2.0 +(FOOT_X -LEG_X)/2.0))) L_Foot.Message(c4d.MSG_UPDATE) c4d.EventAdd()
Any ideas how to fix it???
Thanx in advance for any or no answers
