On 04/06/2013 at 11:27, xxxxxxxx wrote:
hi
is it possible to use a inexclude field in a description and control it with python ?
Thanks Michael
On 04/06/2013 at 12:55, xxxxxxxx wrote:
The description symbol is IN_EXCLUDE.
On 04/06/2013 at 13:45, xxxxxxxx wrote:
hey niklas -
many thanks - again !
On 04/06/2013 at 14:43, xxxxxxxx wrote:
i try to add a objekt and fill the inexclude list but - get an error (has now attribute FG_Fixtures)
node.InsertUnder(op) for obs in activefixtures: node[c4d.FG_Fixtures].InsertObject(obs, 1) c4d.EventAdd()
On 04/06/2013 at 14:53, xxxxxxxx wrote:
You have to allocate a InExcludeData object, there is a difference between a CustomDataType description element and its wrapping class.
edit: lol, didn't red my own link properly, what i meant was, you have to do something like that.
myInExcludeData = c4d.InExcludeData(node[c4d.FG_Fixtures]) myInExCludeData .InsertObject(...
On 04/06/2013 at 15:39, xxxxxxxx wrote:
i try it like you- and dont get an error but the object isnt in the list
node.InsertUnder(op) MyInExcludeData = c4d.InExcludeData(node[c4d.FG_Fixtures]) for obs in activefixtures: MyInExcludeData.InsertObject(obs, 1) c4d.EventAdd()
On 04/06/2013 at 15:59, xxxxxxxx wrote:
your code is correct accept from the fact that you should write your InEx data back into the node, otherwise the EventAdd() does not make much sense.
node[c4d.FG_Fixtures] = myInEx
On 04/06/2013 at 16:32, xxxxxxxx wrote:
great thanks
On 04/06/2013 at 21:24, xxxxxxxx wrote:
Always show the message of an error. It was easy to guess in this case, but it isn't always this way.
