Re-using generator cache
On 21/05/2013 at 02:18, xxxxxxxx wrote:
Cinema 4D Version:
Platform:
Language(s) :---------
Hello,I was wondering what the proper way of re-using a generator's cache is. How does Cinema know
I re-used the cache? And what if I only want to re-use certain parts of the cache?For example:
/* .. */ GetVirtualObjets(BaseObject* host, HierarchyHelp* hh) { // .. BaseObject* root = BaseObject::Alloc(Onull); BaseObject* cache = host->GetCache(); BaseObject* obj = NULL; if (cache) { obj = cache->GetDown(); if (obj) obj->Remove(); } if (!obj) obj = BaseObject::Alloc(Ocube); if (obj) obj->InsertUnder(root); // .. return root; }
Can I do this safely?
Thanks,
-Niklas
On 21/05/2013 at 03:22, xxxxxxxx wrote:
I don't get the question, simply copy the atom you grabbed from the cache ? Are you trying
to keep some sort of live link to the generators cache ? I am not sure what happens if you
do insert parts of an objects cache into the document. What do you expect the generator
object to do ? It has either to rebuild the cache (and set it at some point to Null) or not.my cheap pythonish cents,
happy rendering,
On 21/05/2013 at 03:26, xxxxxxxx wrote:
The point is to not copy/reallocate the object for optimizing the object generating.
Anyway, I just checked and so far it seems to work fine. I remove the object I want to re-use
from the cache (which is the parent) and I didn't get crashes or memory leaks. :)Best,
-nik
