On 16/05/2013 at 06:45, xxxxxxxx wrote:
User Information: Cinema 4D Version: R14+ Platform: Windows ; Language(s) :
--------- How can I get the world matrix of the scene camera in a parallel view such as Left?
BaseObject->GetMg() on the scenecamera returns the rotation portion as an identify matrix.
Markus
On 16/05/2013 at 06:52, xxxxxxxx wrote:
The matrix does not only contain the rotation and with it the scale, but also the position. You can access it via the off attribute.
Best, -Niklas
On 17/05/2013 at 03:18, xxxxxxxx wrote:
Sorry. I don't understand.
I have a "Left" Camera. I do:
BaseDraw* editor = doc->GetActiveBaseDraw(); if (!editor) return false; cam = editor->GetSceneCamera(doc); if (!cam) return false; Matrix camRotMat = cam->GetMg();
I get: [1 0 0 0 1 0 0 0 1 0 0 0]
Which is obviously wrong.
On 17/05/2013 at 03:33, xxxxxxxx wrote:
the matrix is correct. orthogonal cameras are not aligned like perspective cameras. every orthogonal has that matrix unless you do specifically rotate them.
edit : the offset can vary of course ...
On 17/05/2013 at 04:35, xxxxxxxx wrote:
Sorry I totally disagree that the matrix is correct.
How can I offset the camera to the right if I don't know which axis that is?
i.e. CameraObject->SetOffset(CameraObject->GetOffset() + Vector(100,0,0))
only moves the camera left in the "Front", "Top" and "Botton: cameras (because the x-axis is to the right)
Or is there another way of doing this?
On 21/05/2013 at 10:40, xxxxxxxx wrote:
Yep. To get the correct camera matrix use the BaseView instead. There the GetMg() function also gets the global object matrix of the current camera object. But this time it is correct.
