Problems with Edit Slider
On 14/05/2013 at 11:15, xxxxxxxx wrote:
When I assign a value in InitValues(self) for an EditSlider, I can't use the slider anymore (it stays at the same value). So when I try to get the value it doesn't work, because the slider can't be edited.
I've followed the Python SDK instructions, but I'm not getting any further.
Are there special things I have to do to make it work?Greetings,
Casimir
On 14/05/2013 at 13:04, xxxxxxxx wrote:
post your code.
On 15/05/2013 at 06:44, xxxxxxxx wrote:
Here is the code:
import os
import sys
from c4d import gui, plugins, bitmaps, documents, utils
from c4d.modules import mographPLUGIN_ID = 1000003 # Test ID
#Global Variables
FOOT_X = 16.0
FOOT_Y = 4.0
FOOT_Z = 24.0#Groups
GroupFoot = 20100
#CreateObjectMethods
def AddLeftFoot(doc) :
global L_Foot
L_Foot = c4d.BaseObject(c4d.Ocube)
L_Foot[c4d.PRIM_CUBE_LEN, c4d.VECTOR_X] = FOOT_X
L_Foot[c4d.PRIM_CUBE_LEN, c4d.VECTOR_Y] = FOOT_Y
L_Foot[c4d.PRIM_CUBE_LEN, c4d.VECTOR_Z] = FOOT_Z
L_Foot[c4d.ID_BASEOBJECT_REL_POSITION,c4d.VECTOR_Y] = FOOT_Y/2
L_Foot.SetName('L_Foot')
doc.InsertObject(L_Foot)
c4d.EventAdd()#SliderDialog
class InitializeSubDialog(c4d.gui.SubDialog) :
def CreateLayout(self) : #Layout
self.SetTitle("Character Values")
#Group Foot
self.GroupBegin(GroupFoot, c4d.BFH_SCALEFIT, 2, 0, "Foot")
self.GroupBorderSpace(5, 5, 5, 5)
self.GroupBorder(c4d.BORDER_GROUP_IN)
self.AddStaticText(0, c4d.BFH_LEFT, 0, 0, "Foot_X", 0)
self.AddEditSlider(20101, c4d.BFH_SCALEFIT, 500, 0)
self.GroupEnd()
return Truedef InitValues(self) : #Initialize Layout Values (Called when the dialog is initialized by the GUI.)
self.SetReal(id = 20101, value = None, min = 5.0, max = 20.0, step = 1.0, format = c4d.FORMAT_METER)
return Truedef Command(self, id, msg) : #Commands
global L_Foot
if (id == 20101) : #Foot_X SLider
FOOT_X = self.GetReal(20101)
return True#InitialDialog
class InitializeDialog(c4d.gui.GeDialog) :
self.SetTitle("Character Creator")self.AddStaticText(0, c4d.BFH_CENTER, 0, 0, "GENDER", 0)
self.AddComboBox(10001, c4d.BFH_CENTER, 200, 0)
self.AddChild(10001, 0, "MALE")
self.AddChild(10001, 1, "FEMALE")
self.AddSeparatorH(200, c4d.BFH_CENTER)
self.AddButton(10002, c4d.BFH_CENTER, 150, 0, "Create Character")
if (id == 10002) : #Button Create Character
GENDER = self.GetLong(10001)
print GENDER
AddLeftFoot(doc)
InitializeSubDialog().Open(dlgtype = c4d.DLG_TYPE_ASYNC, pluginid = PLUGIN_ID, defaultw = 500, defaulth = 600)
return Truec4d.EventAdd()
class Initialize(c4d.plugins.CommandData) :
dialog = None
def Init(self, op) :
return Truedef Message(self, type, data) :
return Truedef Execute(self, doc) :
if self.dialog is None:
self.dialog = InitializeDialog()
return self.dialog.Open(dlgtype = c4d.DLG_TYPE_ASYNC, pluginid = PLUGIN_ID, defaultw = 200, defaulth = 160)if __name__ == "__main__":
bmp = c4d.bitmaps.BaseBitmap()
dir, file = os.path.split(__file__)
fn = os.path.join(dir, "res", "IconChar.tif")
bmp.InitWith(fn)
print "Character Creator Loaded."
result = plugins.RegisterCommandPlugin(PLUGIN_ID, "Character Creator", 0, bmp, "Character Creator", Initialize())
On 15/05/2013 at 07:36, xxxxxxxx wrote:
And when I don't assign a value in the SetReal, I can use the slider and get information out of it.
On 15/05/2013 at 08:19, xxxxxxxx wrote:
Not relates to your problem, but you will have problems if you store L_Foot globally. Better store it somewhere else than the global scope (eg from where you call AddLeftFoot(), and return L_Foot in this function)
On 15/05/2013 at 09:28, xxxxxxxx wrote:
Ditto what Nik said.
It's ok to use globals in C4D plugins. But try not to get carried away with them.
Put those kinds of values into your methods parameters whenever possible. It will be less confusing later on.The reason you're having trouble with your slider is because the main GeDialog needs an instance of the subdialog in it so it can talk to the sub dialog properly.
Here's an example how to set up the dialogs:
import c4d import os import sys from c4d import gui, plugins, bitmaps, documents, utils PLUGIN_ID = 1000003 # Test ID GroupFoot = 2000 FOOT_X_TEXT = 1000 FOOT_X_SLIDER = 1001 ###### The sub dialog ###### class InitializeSubDialog(gui.GeDialog) : #<--You don't need to use "subdialog" ...It can just be another GeDialog def CreateLayout(self) : self.SetTitle("Character Values") #Group Foot self.GroupBegin(GroupFoot, c4d.BFH_SCALEFIT, 2, 0, "Foot") self.GroupBorderSpace(5, 5, 5, 5) self.GroupBorder(c4d.BORDER_GROUP_IN) self.AddStaticText(FOOT_X_TEXT, c4d.BFH_LEFT, 0, 0, "Foot_X", 0) self.AddEditSlider(FOOT_X_SLIDER, c4d.BFH_SCALEFIT, 500, 0) self.GroupEnd() return True def InitValues(self) : self.SetReal(id = FOOT_X_SLIDER, value = 5.0, min = 5.0, max = 20.0, step = 1.0, format = c4d.FORMAT_METER) return True def Command(self, id, msg) : if (id == FOOT_X_SLIDER) : print self.GetReal(FOOT_X_SLIDER) #Print the value of the slider return True ###### The main dialog ###### class InitializeDialog(gui.GeDialog) : subdlg = InitializeSubDialog() #The sub dialog's local class member instance <--- Very important!!!!! def CreateLayout(self) : self.SetTitle("Character Creator") self.AddStaticText(0, c4d.BFH_CENTER, 0, 0, "GENDER", 0) self.AddComboBox(10001, c4d.BFH_CENTER, 200, 0) self.AddChild(10001, 0, "MALE") self.AddChild(10001, 1, "FEMALE") self.AddSeparatorH(200, c4d.BFH_CENTER) self.AddButton(10002, c4d.BFH_CENTER, 150, 0, "Create Character") return True def InitValues(self) : return True def Command(self, id, msg) : if (id == 10002) : #Button Create Character GENDER = self.GetLong(10001) print GENDER doc = c4d.documents.GetActiveDocument() self.subdlg.Open(dlgtype = c4d.DLG_TYPE_ASYNC, defaultw = 500, defaulth = 600) c4d.EventAdd() return True class Initialize(c4d.plugins.CommandData) : dialog = None def Init(self, op) : return True def Message(self, type, data) : return True def Execute(self, doc) : if self.dialog is None: self.dialog = InitializeDialog() return self.dialog.Open(dlgtype = c4d.DLG_TYPE_ASYNC, pluginid = PLUGIN_ID, defaultw = 200, defaulth = 160) if __name__ == "__main__": bmp = c4d.bitmaps.BaseBitmap() dir, file = os.path.split(__file__) fn = os.path.join(dir, "res", "IconChar.tif") bmp.InitWith(fn) result = plugins.RegisterCommandPlugin(PLUGIN_ID, "Character Creator", 0, bmp, "Character Creator", Initialize())
On 15/05/2013 at 10:34, xxxxxxxx wrote:
Thanks for saying where to store my variables, still having a bit trouble with python variables, im more used with C++. And how do you mean, not relates to your problem?
I really have no clue how to get that slider good.Greets,
Casimir
On 15/05/2013 at 10:36, xxxxxxxx wrote:
Thanks for your answer scott!! I just saw it when I posted my other reply, I think it will be fine now :)
Greets
On 15/05/2013 at 10:42, xxxxxxxx wrote:
You have to pass a float to GeDialog.SetReal() as the value parameter. None won't work.
I think that is breaking the slider. You also did not implement RestoreLayout() despite the
fact that you did instantiate a non modal dialog which will generally end in a mess.You should also always implement object.__int__() for each class. also use constantly self.
Both things are not mandatory but are considered as good style for a reason.
On 15/05/2013 at 10:57, xxxxxxxx wrote:
Ok, thanks for your answers guys!
