Bitmap in UserArea
  • On 12/05/2013 at 13:34, xxxxxxxx wrote:
    Ok so first of all: You should always draw a background color if what you can not assume what
    you are drawing fills the complete rectangle. The buffer is not simply all set to zero (black) but
    is left the way it is. You must fill it with the desired background color yourself.
    Second is: You can actually draw outside of the area because the dialog itself is drawn on the same
    buffer. You can clip the drawing by using SetClippingRegion(x1, y1, x2, y2)
        def DrawMsg(self, x1, y1, x2, y2, msg) :
            self.DrawSetPen(c4d.COLOR_BG)
            self.DrawRectangle(x1, y1, x2, y2)
            self.SetClippingRegion(x1, y1, x2, y2)
            w = self.bmp.GetBw()
            h = self.bmp.GetBh()
            self.DrawBitmap(self.bmp, self.xValue, self.yValue, w, h, 0, 0, w, h, c4d.BMP_ALLOWALPHA)
            self.DrawBorder(c4d.BORDER_OUT, x1, y1, x2, y2)
    -Niklas
  • On 12/05/2013 at 14:24, xxxxxxxx wrote:
    No worries. I've got it all worked out now.
    It just didn't like the way I was using the class member variables.
    Here's the working version. Just in case anyone needs it. Or is curious about it.
    When the GeDialog button is clicked. The image moves to a new position properly now.
    I also threw in some mouse position checking code.
    import  c4d,os
    from c4d import gui, plugins
    class MyUA(c4d.gui.GeUserArea) :
      xValue = 0           #These variables will set the position of the image
      yValue = 0
      def __init__(self) :
          dir, file = os.path.split(__file__)   #Gets the plugin's directory
          path = os.path.join(dir, "res")       #Adds the res folder to the directory to target the res folder
          image = path + "\myimage.png"         #Adds the image to the path
          self.bmp = c4d.bitmaps.BaseBitmap()   #Create an instance of the BaseBitmap class
          self.bmp.InitWith(image)              #Initialize it with the image
          self.xValue = 5
          self.yValue = 5
          self.DrawSetPen(c4d.COLOR_BG)         #COLOR_BG is the image we load with DrawBitmap
          self.DrawRectangle(x1, y1, x2, y2)    #Draws a rectangle and fills it with the image bitmap
          w, h = self.bmp.GetSize()             #Gets the size values of the image
          self.DrawBitmap(self.bmp, x1 + self.xValue, y1 + self.yValue, w, h, 0, 0, w, h, c4d.BMP_NORMAL | c4d.BMP_ALLOWALPHA)
          self.DrawBorder(c4d.BORDER_ROUND, x1+5, y1+5, x2-5, y2-5)  #Draws a border around the UserArea
      def InputEvent(self, msg) :
          action = c4d.BaseContainer(c4d.BFM_ACTION)
          action.SetLong(c4d.BFM_ACTION_ID, self.GetId())
          while self.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, msg) :    #While the left mouse button is held down
              if msg.GetLong(c4d.BFM_INPUT_VALUE)==0: break
              if msg[c4d.BFM_INPUT_DEVICE] == c4d.BFM_INPUT_MOUSE:
                  x, y = msg[c4d.BFM_INPUT_X], msg[c4d.BFM_INPUT_Y]
                  g2l  = self.Global2Local()
                  x += g2l['x']
                  y += g2l['y']
              if msg[c4d.BFM_INPUT_CHANNEL] == c4d.BFM_INPUT_MOUSELEFT:
                  print x, y  #The mouse's X & Y pos inside the user area
                  action.SetLong(c4d.BFM_ACTION_INDRAG, True)
                  self.SendParentMessage(action)                    #Sends a message to the parent dialog that the mouse is dragging in the UA
                  self.Redraw()                                     #Redraw while the left mouse button is held down
          action.SetLong(c4d.BFM_ACTION_INDRAG, False)
          self.SendParentMessage(action)                            #Sends a message to the parent dialog that the mouse has stopped dragging in the UA
    class MyDialog(c4d.gui.GeDialog) :
      ua = MyUA()                #Create a local class instance of the UserArea
      def CreateLayout(self) :
          self.AddUserArea(2000, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT)
          self.AttachUserArea(self.ua, 2000)
          self.AddButton(1000, c4d.BFH_CENTER, 80, 15, "Click Me")
          self.AddButton(1001, c4d.BFH_CENTER, 80, 15, "Close")
      #This method initializes things when the plugin starts
      def InitValues(self) :
      def Command(self, id, msg) :
          if id==1000:
              self.ua.xValue = 100
              self.ua.yValue = 100
              self.ua.Redraw()
          elif id==1001:
              self.Close()
    ###### This class is only used to register the plugin...Don't change!!!#######
    class BitmapUaExample(c4d.plugins.CommandData) :
      dlg = None
      ua = None
      PLUGIN_ID   = 10000090 # TESTING ID ONLY!!!
      ICON = None
      def Execute(self, doc) :
          if not self.dlg: self.dlg = MyDialog()
          self.dlg.Open(c4d.DLG_TYPE_ASYNC, self.PLUGIN_ID, -1, -1, 400, 300)
      def RestoreLayout(self, subid) :
          if not self.dlg:
          return self.dlg.Restore(self.PLUGIN_ID, subid)
      @classmethod
      def Register(myPlugin) :
          data = {
              "id":     myPlugin.PLUGIN_ID,
              "icon":   myPlugin.ICON,
              "str":    "Bitmap UA Example",
              "help":   "Some text that shows up at the bottom of the C4D UI",
              "info":   c4d.PLUGINFLAG_COMMAND_HOTKEY,
              "dat":    myPlugin(),
          c4d.plugins.RegisterCommandPlugin(**data)
      BitmapUaExample.Register()
