On 01/05/2013 at 13:39, xxxxxxxx wrote:
User Information: Cinema 4D Version: R14 Platform: Windows ; Language(s) : C++ ; PYTHON ;
--------- Hi!
Can someone provide a working example of BaseDraw::DrawTexture()? It just doesn't do what I want so I'm doing something wrong and I can not figure it out.
Some C++ Code:
Rect_t rect; bd->GetSafeFrame(&rect.x1, &rect.y1, &rect.x2, &rect.y2); // ... bd->SetMatrix_Screen(); Vector padr4[4]; padr4[0] = Vector(rect.x1, rect.y1, 0); padr4[1] = Vector(rect.x2, rect.y1, 0); padr4[2] = Vector(rect.x2, rect.y2, 0); padr4[3] = Vector(rect.x1, rect.y2, 0); Vector cadr[4] = { Vector(0.5) }; Vector vnadr[4] = { Vector(0, 0, 1) }; Vector uvadr[4]; uvadr[0] = Vector(0, 0, 0); uvadr[1] = Vector(1, 0, 0); uvadr[2] = Vector(1, 1, 0); uvadr[3] = Vector(0, 1, 0); bd->DrawTexture(bmp, padr4, cadr, vnadr, uvadr, 4, DRAW_ALPHA_NORMAL, DRAW_TEXTUREFLAGS_INTERPOLATION_LINEAR);
A Python Version:
f = bd.GetSafeFrame() w = f['cr'] - f['cl'] h = f['cb'] - f['ct'] # ... bmp = BaseBitmap() bmp.Init(w, h, 24) for x in xrange(w) : for y in xrange(h) : bmp[x, y] = (x, y, 50) padr4 = [None] * 4 padr4[0] = Vector(f['cl'], f['ct'], 0) padr4[1] = Vector(f['cr'], f['ct'], 0) padr4[2] = Vector(f['cr'], f['cb'], 0) padr4[3] = Vector(f['cl'], f['cb'], 0) cadr = times(4, Vector) vnadr = times(4, lambda: Vector(0, 0, 1)) uvadr = [None] * 4 uvadr[0] = Vector(0, 0, 0) uvadr[1] = Vector(1, 0, 0) uvadr[2] = Vector(1, 1, 0) uvadr[3] = Vector(0, 1, 0) bd.SetMatrix_Screen() bd.DrawTexture(bmp, padr4, cadr, vnadr, uvadr, 4, c4d.DRAW_ALPHA_NONE, c4d.DRAW_TEXTUREFLAGS_INTERPOLATION_NEAREST)
For the Python Version, all I get is a black screen:
I can't really describe the behavior as the behavior seems rather random to me. For example, changing the cadr array a little:
cadr = times(4, Vector) cadr[0].x = 255 cadr[1].y = 255
Looks quite funny:
Thanks in advance! -Niklas
On 01/05/2013 at 14:03, xxxxxxxx wrote:
Okay, nevermind. Seems like the colors from the cadr array are drawn in "over" the texture (in some strange way). So, this basically works arleady really good!
Rect_t rect; bd->GetSafeFrame(&rect.x1, &rect.y1, &rect.x2, &rect.y2); // Draw the overlay image on the screen. BaseBitmap* bmp = image->GetBitmap(); if (!bmp) return TRUE; bd->SetMatrix_Screen(); Vector padr4[4]; padr4[0] = Vector(rect.x1, rect.y1, 0); padr4[1] = Vector(rect.x2, rect.y1, 0); padr4[2] = Vector(rect.x2, rect.y2, 0); padr4[3] = Vector(rect.x1, rect.y2, 0); Vector uvadr[4]; uvadr[0] = Vector(0, 0, 0); uvadr[1] = Vector(1, 0, 0); uvadr[2] = Vector(1, 1, 0); uvadr[3] = Vector(0, 1, 0); bd->DrawTexture(bmp, padr4, NULL, NULL, uvadr, 4, DRAW_ALPHA_FROM_IMAGE, DRAW_TEXTUREFLAGS_0);
But the alpha display is not really satisfieng:
I am drawing Noise on the GeClipMap using this algorithm:
image->BeginDraw(); for (LONG x=0; x < width; x++) { for (LONG y=0; y < height; y++) { Real v = (SNoise(Vector(x / 50.0, y / 50.0, frame)) + 1) / 2; v *= (Real) x / width; LONG g = (LONG) (v * 255); image->SetPixelRGBA(x, y, 255, 255, 255, g); } } image->EndDraw();
Is there anything wrong or is it a limitation of the DrawTexture() method?
Thanks, -Niklas
