Curious about Browser->IsDir()
  • On 28/04/2013 at 21:10, xxxxxxxx wrote:
    Cinema 4D Version:   R14
    Platform:   Windows  ;
    Hi Folks,
    I'm just curious about what the difference is between the following code snippets. The first one works, but the second one doesn't:
    // Folder is an AutoAlloc BrowseFiles...
    if(Folder->IsDir())
        GePrint("This way works...!");
    if(Folder->IsDir() == TRUE)
        GePrint("This way doesn't work...");
    What's the technical/C++ difference here and why does one way work but the other not? I'm just curious because having Folder->IsDir() == FALSE works fine, but having TRUE does not..
    WP.
  • On 29/04/2013 at 06:56, xxxxxxxx wrote:
    Well Bool in C4D SDK is actually an Integer (int)  while FALSE if 0 and TRUE is 1.
    The problem is that Bool can also be 5 or any other Integer value.
    If IsDir() return some other value as 1 for true then if(IsDir()) will work but if(IsDir()==TRUE) will not work because if(5 == 1) is false.
    Some times C4D SDK uses NOTOK = (-1)  as a Bool value too.
  • On 29/04/2013 at 13:28, xxxxxxxx wrote:
    While it is true that Bool is an integer, it should be returning strict TRUE/FALSE values.  The docs say that it returns TRUE if this is a directory.  So, the second conditional should be working or it's a bug in the SDK (or your code).
  • On 29/04/2013 at 13:53, xxxxxxxx wrote:
    not sure how it is in cpp, but in python and c# the lazy ass implicit notation behaves different
    than the explicit notation.
    def foo(v) :
        if v: print 'imp', True
        else: print 'imp', False
        if v == True: print 'exp', True
        else: print 'exp', False
    print 0
    foo(0)
    print -1
    foo(-1)
    \>>0
    \>>imp False
    \>>exp False
    \>>-1
    \>>imp True
    \>>exp False
  • On 29/04/2013 at 14:19, xxxxxxxx wrote:
    @littledevil: The same in example in C++ will print the same results.
    http://ideone.com/JgkQcJ
    Best,
    -Niklas
  • On 29/04/2013 at 14:48, xxxxxxxx wrote:
    Originally posted by xxxxxxxx
    <ADDRESS>
    Platform:   Windows  ;
    Language(s) :
    C++  ;
    </ADDRESS> Hi Folks,
    if(Folder->IsDir())
    WP.
    It's a Windows specific bug (on the Mac it's fine) - the return value on Windows is the Win32 FILE_ATTRIBUTE_DIRECTORY constant (instead of TRUE). I'll file a bug for it. For the time being please use the code block of your first scope as workaround instead of comparing it with "TRUE".
    Best regards,
    Wilfried
  • On 29/04/2013 at 19:01, xxxxxxxx wrote:
    Thanks again everyone.
    WP.
