On 28/04/2013 at 11:26, xxxxxxxx wrote:
Hi everyone
I am new in Phyton and I'm trying to change Falloff shape from infinity to linear in a plain effector but get the following error.
AttributeError: parameter set failed
When I change the weight slider it works fine
What am I missing? Here is the code.
def main() : plain = c4d.BaseObject(1018643) doc.InsertObject(plain) plain[c4d.FALLOFF_STRENGTH] = 0 #<<<< this works fine plain[c4d.FALLOFF_MODE] = 2 if __name__=='__main__': main()
On 28/04/2013 at 11:50, xxxxxxxx wrote:
each falloff type is a separate plugin/class. you have to pass the proper id.
from ofalloff_panel.h
#ifndef _Ofalloff_panel_H_ #define _Ofalloff_panel_H_ enum { //Falloff mode ID's FALLOFF_MODE_INFINITE = 1019543, FALLOFF_MODE_BOX = 1019544, FALLOFF_MODE_SPHERE = 1019545, FALLOFF_MODE_CYLINDER = 1019546, FALLOFF_MODE_LINEAR = 1019547, FALLOFF_MODE_SPLINE = 1019548, FALLOFF_MODE_CONE = 1019549, FALLOFF_MODE_TORUS = 1019550, //Falloff controls FALLOFF_GROUPFALLOFF = 5100, FALLOFF_MODE = 5105, FALLOFF_INVERT = 5113, FALLOFF_VISIBLE = 5115 }; #endif
so it would be plain[c4d.FALLOFF_MODE] = c4d.FALLOFF_MODE_SPHERE or something like that.
On 28/04/2013 at 12:39, xxxxxxxx wrote:
Thank you very much!
