On 13/04/2013 at 11:23, xxxxxxxx wrote:
hi,
is it somehow possible to get hold of the bullet solver data in python ? i need collision normals and velocity vectors and would prefer not to carry arround some clunky xpresso node solution. i looked into the MoGraphDynamics SceneHook, but it does only contain the world settings. i also looked into the cpp documentation, but i could not find any information there.
i guess this is mission impossible ?
On 16/04/2013 at 13:24, xxxxxxxx wrote:
any information would be cool, even that it is impossible atm.
and i have got another question : is there known any downside on hosting a pointtag within a pointtag ? or generally a basetag within a basetag ? something like that :
+ myTagGeListNodeA | ---myTagGeListNodeB | ---myTagGeListNodeC
it would be a perfect caching solution for a current problem for me, however i am not sure if i will loose data with such gelistnode structures under certain conditions, as c4d does not expect tags to have children ?
On 17/04/2013 at 02:43, xxxxxxxx wrote:
Hi Ferdinand,
Have you tried to get the MoGraph data (c4d.modules.mograph.MoData) with c4d.modules.mograph.GeGetMoData()?
On 17/04/2013 at 03:51, xxxxxxxx wrote:
Originally posted by xxxxxxxx Hi Ferdinand, Have you tried to get the MoGraph data (c4d.modules.mograph.MoData) with c4d.modules.mograph.GeGetMoData()?
thanks for your reply, but i do not really understand your suggestion. first of all GeGetMoData()returns only for MoGraph cloner objects a MoData instance. but even if i do host the bullet simulation within a cloner, modata does only contain matrix data regarding the mograph particle state for that cloner. i guess i could calculate the velocity out of the current and previous state of the matrix data, but the previous state field is not working properly for me (seems broken like the size maxtrix). i could do that also just with the baseobject matrix, but that will leave me with the missing contact points / collision normals.
am i overlooking something important here ? it would be nice if someone could point me into the right direction, if the bullet data is burried somewhere in the modata.
On 18/04/2013 at 03:57, xxxxxxxx wrote:
I got more information on this from the developers. There are no velocity vectors or collision normals stored in the MoData; MoGraph particles have no velocity, anything that happens to them is inherited. It's possible though that it could be calculated from the matrices and storing the previous frames data.
On 18/04/2013 at 06:13, xxxxxxxx wrote:
thanks again for your reply. it would be cool if you would consider exposing some of the bullet solver data on a code level in future sdk releases. if i am not mistaken, this is not just a problem in python, but also a cpp problem (at least i could not find a bullet solver interface class in the cpp sdk).
while you can relatively easily calculate the velocity vectors on your own, you cannot do that for collision normals, force vectors and so on. i am not asking for exposing/wrapping the whole bullet class system, just for exposing the bullet data in the current scene. as there are the xpresso nodes doing exactly that it cannot be too hard
