On 26/03/2013 at 02:29, xxxxxxxx wrote:
--------- Hi folks, I'm trying to modify the LayerSet of a BitmapShader. But I always get a NULL pointer with the following code:
BaseShader *tex = BaseShader::Alloc(Xbitmap); if (!tex) { BaseMaterial::Free(mat); return NULL; } mat->InsertShader(tex); tex->SetParameter(BITMAPSHADER_FILENAME, GeData(Filename("...")), DESCFLAGS_SET_0); GeData dLayerSet; if (tex->GetParameter(BITMAPSHADER_LAYERSET, dLayerSet, DESCFLAGS_GET_0)) { LayerSet *layerSet = static_cast<LayerSet*>(dLayerSet.GetCustomDataType(CUSTOMDATATYPE_LAYERSET)); if (layerSet) { layerSet->SetMode(LAYERSETMODE_LAYERALPHA); } }
Does anyone know what's wrong here? Thanks in advance! Satara
On 26/03/2013 at 04:03, xxxxxxxx wrote:
Ok seems that I have to allocate it by myself. This works fine:
LayerSet *layerSet = static_cast<LayerSet*>(dLayerSet.GetCustomDataType(CUSTOMDATATYPE_LAYERSET)); if (!layerSet) layerSet = LayerSet::Alloc(); if (layerSet) { layerSet->SetMode(LAYERSETMODE_ALPHAS); layerSet->AddLayer("Alpha"); dLayerSet.SetCustomDataType(CUSTOMDATATYPE_LAYERSET, *layerSet); tex->SetParameter(BITMAPSHADER_LAYERSET, dLayerSet, DESCFLAGS_SET_0); }
On 26/03/2013 at 08:14, xxxxxxxx wrote:
Hi Satara,
Thanks for posting the code. But I'm having a hard time getting your code to work. And I can't find much information about the LayerSet type.
This code produces an "unexpected type" compile error:
Are you including this header file?: customgui_layerset.h Or some other header file?
On 26/03/2013 at 09:04, xxxxxxxx wrote:
Never mind. I figured it out. This is the missing piece of code that makes the rest of your code work:GeData dLayerSet;
