moving a texture tag
On 25/03/2013 at 12:24, xxxxxxxx wrote:
Cinema 4D Version: r14
Platform: Mac OSX ;
Language(s) : C.O.F.F.E.E ;---------
Using c.o.f.f.e.e., i need to move a texture tag from one object to another one.
Any help would be appreciate,
Thanks a lot,
Jean
On 25/03/2013 at 22:49, xxxxxxxx wrote:
Assuming that you already have the source object (sobj) and the destination object (dobj), this is all you need to do:
var ttag; for (ttag = sobj->GetFirstTag(); ttag; ttag = ttag->GetNext()) { if (!instanceof(ttag, Ttexture)) continue; ttag->Remove(); dobj->InsertTag(ttag); break; }
On 26/03/2013 at 18:46, xxxxxxxx wrote:
Hi Robert,
Thanks + thanks + thanks.
Jean
On 26/03/2013 at 19:19, xxxxxxxx wrote:
If you want to move multiple texture tags, just remove the "break;" line in the code and all texture tags on the source object will be moved to the destination object.
