On 21/03/2013 at 15:06, xxxxxxxx wrote:
User Information: Cinema 4D Version: 13 Platform: Mac ; Language(s) : C++ ;
--------- Hello all, back with a couple more question, this time about the Bitmap Distortion Shader.
I've been experimenting with it and I've found some things that I don't understand.
Does ShaderData::Output() browse through the points in any specific order? From the print tests I've done it seems to be essentially random.
How would I find adjacent points to the current cd->p point? And what defines a point? They don't seem to be evenly spaced or anything from what I can tell.
Thanks for any possible help. Dan
On 21/03/2013 at 18:21, xxxxxxxx wrote:
as nobody is answering here, i just drop two things.
1. ChannelData coordinates are in UVW space. you could theoretically sample neighbouring areas by calling output just with a modified ChannelData.uVW value. getting the sample for neighbouring pixels can be quite complicated i guess (as you would have to do the raytracing).
2. the samples are not evenly spaced due to projection a mesh curvature. for a planar surface with an orthgonal frontal projection output should e called in evenly spreaded steps.
