On 14/03/2013 at 03:55, xxxxxxxx wrote:
User Information: Cinema 4D Version: 14 Platform: Windows ; Language(s) :
--------- I found some bug in Bake Texture tag with Displacement option ( 32bit channel format / XYZ ) To put it simply, download Scene.
http://www.elasticmindist.com/bugdisMap.c4d When bake displacement with 8/16bit format, image's background value will 127 ( 0.5 ). But, background value is 55 when bake displacement with 32bit format . and rendering with 32bit image move point to negative XYZ space.
On 14/03/2013 at 04:27, xxxxxxxx wrote:
This isn't the appropriate place to put this. Here you can only report bugs in the SDK (description of the sub-forum is: "Report any bugs found in the SDK"), not in the application itself. Please use this official form instead.
