On 11/03/2013 at 14:17, xxxxxxxx wrote:
Update 2016-01-22: Read this post instead. The information in this thread is old!
Hello fellow developers. Today I want to talk about third-party modules in a Python plugin. It is often necessary to use modules that are not delivered with the CPython distribution in your plugin because of certain functionality they provide. There are two common ways to import external libraries in your plugin, and they both have their advantages and disadvantages.
What we, as developers, might like the most, is to just import the module and don't care about the rest. For this, we have to put the module in a place where the Python interpreter in Cinema can find it.
1. Insert the module in:
{Cinema Preferences Folder}/library/python/packages/{OS Name}
The Python interpreter embedded in Cinema will search for modules there additionally to the standart paths. However, the module has to be copied twice for Windows since there is a win32 and win64 folder and the Python distribution will search in the respective folder depending on the Cinema build you run.
2. Modify the PYTHONPATH environment variable: We can add a path to this environment variable where we can put all external modules we ever want to use. The advantage of this method is that *any* Python installation and not only the Cinema 4D installation will check the paths defined in this environment variable. This way, we only need one copy of the external module on our whole computer.
Either way, the user has to perform this step, too. This isn't actuall a great deal and can be done quickly, but keep in mind that a normal user might not be familar with folder-structures, environment variables and all the stuff. Not kidding, this is not a rare case. The user will also be responsible for updating the external modules when your new version of your plugin requires a newer version, etc. All in all, we end up giving support to the users of our plugins on how to correctly fullfil all dependencies.
How can we make it better?
We can distribute the external dependencies with our plugin. The user will just unpack the plugin archive and it will run. Sounds good, eh? But it's tricky !! First of all, how do we deliver an external module with our plugin?
We will put it into a folder and import it from there, like:
lib\n module.py res\n <resource files> plugin.pyp
And the code to load the module:
import os import sys dirname = os.path.dirname(__file__) lib_path = os.path.join(dirname, 'lib') sys.path.insert(0, lib_path) try: import module finally: # Remove the path we've just inserted. sys.path.pop(0)
Notice the try/finally clause. Even when an error occures while loading one of the modules within the try-block, the finally block garuantees that the path we have added will be removed again!
So where's the tricky part?
Let's make this more fancy and say that we have two plugins relieng on the same module, for the sake of example we will call this module "module". Therefor, we got wo plugins, one dependency, but both distribute the module with them.
# plugin1.pyp import module # plugin2.pyp import module
Yet, there is not problem. But it comes to a problem when the plugins rely on different versions of the module. Eg. plugin2 relies on version 2 of the module while plugin1 is already satisfied with version 1. Version 2 added new functions to the module.
# plugin1.pyp import module module.some_func() # plugin2.pyp import module module.some_func() module.new_func()
The call to module.new_func() can easily fail when plugin1 is loaded before plugin2. After plugin1 imported the module in version 1, the module resides in the sys.modules dictionary, and this is the place where the import mechanism of Python looks in the first place before searching for the module on the HD.
sys.modules
Once again: When plugin1 is loaded before plugin2, import module will load "module.py" from plugin1 into plugin2 and not "module.py" from the plugin2! The module loaded by plugin1 might even be a completely different one than plugin2 but have the same name. In this case, one of the plugins is condenced to fail!
How to fix?
You should always remove modules imported from your plugin-local folder from sys.modules (not to mention to remove the path added to sys.path to actually import the module). Best practice is to restore the old module configuration after importing local libraries.
# Store the old module configuration. old_modules = sys.modules.copy() # Import your stuff, for example: lib_path = os.path.join(os.path.dirname(__file__), 'lib') sys.path.insert(0, lib_path) try: import module finally: sys.path.pop(0) # Restore the previous module configuration making sure to not # remove modules not loaded from the local libraries folder. for k, v in sys.modules.items() : if k not in old_modules and hasattr(v, '__file__') or not v: if not v or v.__file__.startswith(lib_path) : sys.modules.pop(k) else: sys.modules[k] = v
Edit: I have hit strange errors when removing modules loaded by a module from the local plugin distribution that are from the Python standard library or at least not from the plugin's lib dir. With hasattr(v, '__file__') we're checking if the module is a built-in module or not. If it isn't, we check if the filename of the module starts with the lib_path of our plugin. If so, we can safely remove it!
But note that you should remove built-in modules when they are distributed with your plugin (native modules referring to C/C++ modules with *.pyd suffix)! Imagine you are delivering the _ssl module for Windows with your plugin, then do it like this:
# .. add lib path to sys.path and store old module configuration import _ssl del sys.modules['_ssl'] # ... remove modules like above!
The code above would be too complex to put it into a one-line expression, which is why I striked through the following block: If you're feeling nasty, you can also put the last five lines into a one-liner (just split up for readability) : ~~ ~~ [sys.modules.__setitem__(k, v) if k in old_modules else sys.modules.pop(k) ~~ for k, v in sys.modules.items()]~~
Conclusion : Do always ensure that you do not influence other plugins by importing external modules.
edit: 2013/03/13 Reloading modules at runtime
Cinema 4D allows us to reload Python plugins at runtime so we do not have to restart the application after making changes to a plugin. However, loaded modules not be reloaded with this command. There's a reload() function built-in to Python so we can use it in PluginMessage() and react on the C4DPL_RELOADPYTHONPLUGINS message.
def PluginMessage(msg, data) : if msg == c4d.C4DPL_RELOADPYTHONPLUGINS: reload(module)
But it's more tricky than that. The reload() function only works when the module can be found in sys.modules (which we have removed it from) and if the module can be found via sys.path (we removed the path the module is located at from this list). So, we again have to find a work-around to this. For this workaround, we have to dive into some black magic. We could reload a single module simply by
import sys import imp import types def load_module(module=None, filename=None, name=None) : if module: filename = module.__file__ name = module.__name__ elif not all(filename, name) : raise TypeError('expected a module or both filename and name.') # Obtain the module that was previously stored. prev_mod = sys.modules.get(name, None) # Load the module. new_mod = imp.load_source(name, filename) # The new module has been inserted into sys.modules, we have to # fix that again. if prev_mod: sys.modules[name] = prev_mod else: sys.modules.pop(name) return new_mod def reload_recursive(module) : mod = load_module(module) for name, submodule in vars(module).iteritems() : if isinstance(submodule, types.ModuleType) : new_mod = reload_recursive(submodule) setattr(module, name, new_mod) return mod
But then again, it comes to issues when the module imports modules from your other dependencies, because the modules are not on sys.path. As hacky as it sounds, we have to insert the required paths to sys.path again temporarily. So here's the solution:
import os import sys import imp def get_root_module(modname, suffixes='pyc pyo py'.split()) : r""" Returns the root-file or folder of a module filename. The return-value is a tuple of ``(root_path, is_file)``. """ dirname, basename = os.path.split(modname) # Check if the module-filename is part of a Python package. in_package = False for sufx in suffixes: init_mod = os.path.join(dirname, '__init__.%s' % sufx) if os.path.exists(init_mod) : in_package = True break # Go on recursively if the module is in a package or return the # module path and if it is a file. if in_package: return get_root_module(dirname) else: return os.path.normpath(modname), os.path.isfile(modname) def reload_modules(*modules) : r""" Reload the passed module objects. Restores the previous module configuration after reloading. """ # Find all root-directories of the passed modules. paths = set() for mod in modules: mod_name = mod.__name__ if imp.is_builtin(mod_name) != 0 or not hasattr(mod, '__file__') : raise RuntimeError('cannot reload built-in module %s.' % mod_name) mod_root, is_file = get_root_module(mod.__file__) dirname = os.path.dirname(mod_root) dirname = os.path.normpath(dirname) paths.add(dirname) # Change the system path and store a copy of the current module # configuration. old_path = sys.path old_mods = sys.modules.copy() sys.path = list(paths) + sys.path try: # Reload the modules. new_mods = [] for mod in modules: if mod.__name__ in sys.modules: new_mod = reload(mod) else: new_mod = __import__(mod.__name__) new_mods.append(new_mod) finally: # Restore the import search path and module configuration. sys.path = old_path for k, v in sys.modules.items() : if k not in old_mods: sys.modules.pop(k) return new_mods def PluginMessage(msg, data) : if msg == c4d.C4DPL_RELOADPYTHONPLUGINS: global module module, = reload_modules(module)
Welcome back after reading through this monster for such a "simple task". The reload_modules() function will use the reload() function if the module is available in sys.modules or use the standart import mechanism to import it if the reload() function can not be used.
Holy crap, why should I stick to these rules?
Seriously, just do your fellow developers a favor. And also yourself. And the users of your plguins. I've hit this problem just two days before and that is why I wanted to share the solution with you. Yes, I've hit it myself, with two of my own plugins!
All of the things I've mentioned above to not fuzz other plugins by importing the dependencies would not be a necessity if the users install the dependencies somewhere all plugins can find them (and updates them accordingly to new requirements of other plugins etc.). But as already mentioned, you will either end up giving very much user support or loose users because of this "inconvenience" (it actually is just a 5 minute task, if even).
I admit that I usually tell the users to install the dependency as described above for free plugins. There are also cases were you are actually forced to deliver the dependencies with your plugin. For example, both of my current clients explicitly stated that they want the dependencies to be distribute with the plugins. Ouch, I've spend a lot of time figuring the above out, but since they pay me to do what they want, I'll have to do it.
If you have any questions regarding this topic, please don't hesitate to ask here.
All the best, -Niklas
On 12/03/2013 at 08:08, xxxxxxxx wrote:
hey, good tutorial. something like this should be in in the documentation. as this is targeted at beginners you might want to add a part about relaoding modules, so that you can dabug your modules without having to restart c4d for each change.
On 12/03/2013 at 09:28, xxxxxxxx wrote:
Hi Ferdinand,
thanks for the feedback. Good idea, I'll add this asap.
-Niklas
On 13/03/2013 at 06:19, xxxxxxxx wrote:
I've added "Reloading modules at runtime" and a final word to the entry.
Best, -Niklas
On 14/03/2013 at 07:18, xxxxxxxx wrote:
I have updated the article on built-in modules. I've hit strange errors when a built-in module was removed from sys.modules.
I have hit strange problems when removing non-local modules (eg modules imported by the local distributed modules from the Python STL) from sys.modules. Not removing those fixes the problems and is also more resource efficient!
The post above is updated respectively.
